04-07-2008, 09:01 AM
Post: #411
Looks good Apardal! Shows how important a good tune up is
04-07-2008, 10:04 AM
Post: #412
I really like your video. Nice and healthy sound. Nice driving an nice road
Toyota Corolla KE30 + Toyota Corolla AE86 |
04-07-2008, 10:57 AM
Post: #413
Rasteirinho Wrote:Quote:Cusco gearbox bushing Nope, it's not the gearbox bushing... I have the cusco gearbox bushing, i have installed it last thursday, but i had this noise before. And it's not the center shaft bearing, we lifted up the car, someone was inside, and hitted the accelerator in every gear, and then decelerated. And the bearing is good, it was not vibrating. And the car wasn't vibrating so hard either. So i think it is coming from the rear end. My story about it: I have the same vibration like apardal, exactly the same. I have changed the suspension bushings to prothane with my mechanic, and then this sound came. It's a very bad thing, the whole car vibrates, but only in first, second and third gear when i decelerate and around 3000-3500 rpm. I don't know where it comes from, i'll try to loosen all screws from the suspension, and retighten them, maybe my mechanic did something wrong when changing the bushings. I'll report when i found the what's causing this problem. Daily driver: AE86 - 1985 zenki levin |
04-07-2008, 09:01 PM
Post: #414
hello,
I saw your very nice video,so much power this is very impressive with standard injection system. Do you still use MS with MAP? obviously you manage to control the ignition(VAST) with the MS? would you have some photos of the last setup, engine bay etc.. many thanks and congratulations again for your car! david |
04-07-2008, 11:44 PM
Post: #415
In my engine, besides crank, block and connecting rods, only the intake manifold is stock, but without T-VIS.
The injectors are 300cc's. I'm using MS with MAP and it controls the ignition, of course. My engine bay is rather stock... only intake air filter aftermarket... you will find pictures throughout the post! Thank you for your comments! Best regards |
04-29-2008, 03:37 PM
Post: #416
ITB's @ Home, YUPPPI!!!!
04-30-2008, 11:58 AM
Post: #417
Sweet!
Keep going my friend. When you have it all fitted and running i will ask you to do the same job to my car... Beijinhos Keeping the AE86 alive! |
04-30-2008, 12:08 PM
Post: #418
really nice, I knew you would go with ITB!
are they the big ones? with T3 manifold, that is going to look and sound really nice!! all the best. regards david |
04-30-2008, 12:25 PM
Post: #419
These are the Silvertop/small ones!
Best regards |
06-24-2008, 11:29 AM
Post: #420
Well, just spend 2 hours updating all the links from my project's photos because they were offline for a few months now.
For all of you who have nothing to do and want to spend dead time... everything is back online! About the car itself, the news are that I got new TRD 304ยบ Camshafts that run very poorly with the stock intake and the ITB's have not been installed yet because I'm missing the throttle linkage and lever. I've also installed new oil cooler with new hoses to keep things cool. To keep dirt away from the engine, I bought a Pipercross PX600 air filter that I'll install as soon as the ITB problem is solved. Best regards |
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 50 | 10,715 |
08-21-2026 01:32 PM Last Post: ondafly |
| Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 71,186 |
11-23-2018 10:13 PM Last Post: sylwekgtir |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 22,400 |
| RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 40,222 |
| Shell make over a coat of paint | williep12 | 4 | 9,504 |
02-01-2010 03:52 PM Last Post: Kid Karola |
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](https://lh6.ggpht.com/apardal/SBcg9r8QCUI/AAAAAAAAAHs/zTzStnQi70c/s800/intake%20001.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](https://lh6.ggpht.com/apardal/SBcg-r8QCVI/AAAAAAAAAH0/9_pBV5nnnds/s800/intake%20002.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](https://lh3.ggpht.com/apardal/SBcg_78QCWI/AAAAAAAAAH8/KrahkbBwIsE/s800/intake%20003.jpg)
