03-08-2006, 09:54 AM
Post: #271
apardal Wrote:jamiemirror, can you elaborate on the map signal modding subject? This is not particularly 4AGE article but will work fine: |
03-24-2006, 04:55 PM
Post: #272
apardal,
I found in my archives some additional 4AGE specific ITB modification (something made in the past from japanese tunning company ?). I bet that you can use information from my previous posting (the attachment) to build device for MAP signal modification ! |
04-12-2006, 01:50 PM
Post: #273
Camshaft instalation:
![]() Timing degree wheel! ![]() Measuring cam timing ![]() Tightening camshaft caps. ![]() Safety as a priority! Although it looks fragile... it holds up fine! ![]() ![]() Assemblying rod bearings. ![]() ![]() Finally, we closed the engine, filled it up with oil, tuned the distributor and fired it up. The camshaft and con-rod bearings break-in lasted 15 minutes and it was time for a little run. It idles roughly below 1000 rpm and runs fine over that mark. The distributor advance still needs to be corrected but I think it is running fine right now (without detonation). At the first run the car seemed weaker at low rpm's so I think the TVIS needs to be removed. The high end is better with the engine a lot more loose building up power to 8000 rpm I think. No doubt it is better than before, but it needs a lot of tuning. I have stock ECU, stock injectors, stock intake and exhaust. I have a set of 240 cc injectors laying around to try it out. I don't know if the engine is running lean or rich. I'll try to use the cam gears to pull the power band a little lower. Now it is time for the tune up. Meanwhile I got Tsudo Headers from ebay. They were cheap and you get what you pay for. Some rough edges need to be corrected... ![]() Best regards guys! |
04-12-2006, 01:51 PM
Post: #274
By the way, jamie, thanks a lot for the files... they may come handy sometime
Best regards |
04-12-2006, 01:55 PM
Post: #275
They files are safe here apardal, I almost lost them in my home computer !
Good work man, keep going ! |
04-12-2006, 02:07 PM
Post: #276
Very nice update!
Go on apardal, I like this project!
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
04-12-2006, 02:57 PM
Post: #277
Uhm,
At my moms work they regularly work with those forklifts and they do topple over if you load them wrongly.... I definately would never want to work under a load lifted by a forklift... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-12-2006, 03:33 PM
Post: #278
You're right mux... but if you see it closely, the forklift is supported by a pile of wood at the other side... It wouldn't be easy for it to topple over.
Best regards |
04-12-2006, 06:43 PM
Post: #279
Dyno? Nice work, its just getting better and better!
BTW what black color did you use? Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch
04-12-2006, 08:22 PM
Post: #280
Jan - No dyno yet.
The color code is Black 202! |
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 49 | 9,362 |
08-16-2026 04:44 PM Last Post: Koen |
| Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 70,403 |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 22,012 |
| RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 39,816 |
| Shell make over a coat of paint | williep12 | 4 | 9,406 |
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02321r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02322r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02325r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02328r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02576r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02580r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02581r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02582r.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/carros/online/upgrades/dsc02333r.jpg)
