02-19-2009, 12:36 PM
Post: #451
good results!!!
**COROLLA EE80 - 4AGE 124HP**
03-21-2009, 01:40 AM
Post: #452
maybe 1 of the best project EVER!
Ex ITR JDM ![]() AE86 TRUENO LOVER
03-30-2009, 05:21 PM
Post: #453
![]() They are all scaled?? What HP TQ did you get with each setup? HP should equal TW at 5252rpm. |
03-30-2009, 05:47 PM
Post: #454
According to club4ag tech ref
Cam Timing for 288 should be Max Lift @ IN 100 ATDC/ EX 100 BTDC, or 100/98. Determine true TDC of piston #1 in phase 2 of cycle. Mark on degree wheel. Turn crank & degree wheel 100 ATDC (clockwise) Twist inlet cam in the adj gear until Max Lift occurs. Tighten screws. Turn crank & degree wheel 100 BTDC (anti-clockwise) Twist ex cam in the adj gear until Max Lift occurs. Tighten screws. Cam timing should be set. EXAMPLE OF RESULTS FROM USING CLUB4AG TECH REF: 11:1 wiseco, narrow port 4age (no porting) IN 272/7.5mm lift EX 272/7.5mm lift Cam timing, Max lift IN@100/EX@98 as per club4ag. Exhaust 4-1 w/2" system. 295cc injectors Silvertop ITB, T3 inlet VEMS 3.3 tuned on dyno. ![]() ![]()
04-06-2009, 01:21 PM
Post: #455
Hi irishtwincam!
It's been a while since I last checked my post for updates and sorry for late reply. The graphs are both scaled. Both dyno sheets are available in this project thread. Your numbers look good! Is there something you'd like to know? Best regards |
04-06-2009, 03:08 PM
Post: #456
Could you re do the jpg file but with no scaling.
So hp and tq are all on the same scale It would make it more useful. Thanks. |
04-06-2009, 10:44 PM
Post: #457
How much money have you spent on your car? I am asking you because ... I am just starting to upgrate my levin. And I realy need help from somebody ... My car is the only Hachi Roku in town.
04-14-2009, 11:20 AM
Post: #458
I've spent until now almost 20k. It is too much...
04-14-2009, 02:30 PM
Post: #459
cavey Wrote:you still have the plastic fan connected to the engine? why, is it bad to have a plastic fan |
04-14-2009, 11:13 PM
Post: #460
adenAE86, the plastic fan is directly connected to the crank and as heavy as it is, it steals some horsepower!
Best regards |
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 11 | 796 |
Today 01:07 PM Last Post: ondafly |
| Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 65,148 |
11-23-2018 10:13 PM Last Post: sylwekgtir |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 19,796 |
| RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 36,782 |
| Shell make over a coat of paint | williep12 | 4 | 8,468 |
02-01-2010 03:52 PM Last Post: Kid Karola |
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://img9.imageshack.us/img9/1605/blitzhondaintegratyper.png)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i287.photobucket.com/albums/ll129/afrpardal/comparativo3.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i250.photobucket.com/albums/gg269/twincamdan/DYNO%20SHEETS/JOCTQvsRPMBINS.jpg)
![AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO [Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]](http://i250.photobucket.com/albums/gg269/twincamdan/DYNO%20SHEETS/JOCHPvsRPMBINS.jpg)
