03-08-2006, 09:54 AM
Post: #271
apardal Wrote:jamiemirror, can you elaborate on the map signal modding subject?
Thank You
This is not particularly 4AGE article but will work fine:
03-24-2006, 04:55 PM
Post: #272
apardal,
I found in my archives some additional 4AGE specific ITB modification (something made in the past from japanese tunning company ?).
I bet that you can use information from my previous posting (the attachment) to build device for MAP signal modification !
04-12-2006, 01:50 PM
Post: #273
Camshaft instalation:
Timing degree wheel!
Measuring cam timing
Tightening camshaft caps.
Safety as a priority!
Although it looks fragile... it holds up fine!
Assemblying rod bearings.
Finally, we closed the engine, filled it up with oil, tuned the distributor and fired it up. The camshaft and con-rod bearings break-in lasted 15 minutes and it was time for a little run. It idles roughly below 1000 rpm and runs fine over that mark. The distributor advance still needs to be corrected but I think it is running fine right now (without detonation).
At the first run the car seemed weaker at low rpm's so I think the TVIS needs to be removed. The high end is better with the engine a lot more loose building up power to 8000 rpm I think. No doubt it is better than before, but it needs a lot of tuning. I have stock ECU, stock injectors, stock intake and exhaust. I have a set of 240 cc injectors laying around to try it out. I don't know if the engine is running lean or rich.
I'll try to use the cam gears to pull the power band a little lower.
Now it is time for the tune up.
Meanwhile I got Tsudo Headers from ebay. They were cheap and you get what you pay for. Some rough edges need to be corrected...
Best regards guys!
04-12-2006, 01:51 PM
Post: #274
By the way, jamie, thanks a lot for the files... they may come handy sometime Smile Thumbs up!
Best regards
04-12-2006, 01:55 PM
Post: #275
They files are safe here apardal, I almost lost them in my home computer ! Hurray!
Good work man, keep going !
04-12-2006, 02:07 PM
Post: #276
Very nice update!
Go on apardal, I like this project! Wave
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
04-12-2006, 02:57 PM
Post: #277
Uhm,
At my moms work they regularly work with those forklifts and they do topple over if you load them wrongly.... I definately would never want to work under a load lifted by a forklift...
04-12-2006, 03:33 PM
Post: #278
You're right mux... but if you see it closely, the forklift is supported by a pile of wood at the other side... It wouldn't be easy for it to topple over.
Thumbs up!
Best regards
04-12-2006, 06:43 PM
Post: #279
Dyno? Nice work, its just getting better and better!
BTW what black color did you use?
04-12-2006, 08:22 PM
Post: #280
Jan - No dyno yet.
The color code is Black 202!
  1986 Toyota Corolla Levin 2dr GT-Apex ondafly 39 3,837 Yesterday 05:05 PM
Last Post: ondafly
  Toyota Corolla AE86 LEVIN ( Poland) sylwekgtir 40 66,520 11-23-2018 10:13 PM
Last Post: sylwekgtir
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 20,374 10-07-2018 09:45 PM
  RaceMinded satin black Toyota Corolla AE86 Levin Coupe RaceMinded 22 37,806 09-02-2010 07:25 PM
Last Post: Apolan
  Shell make over a coat of paint williep12 4 8,691 02-01-2010 03:52 PM
Last Post: Kid Karola
