Corolla GT-Z twin cam 16 (4A-GZE)
07-28-2010, 07:00 PM
daniel , doe je het laswerk zelf ?
Ziet er wel netjes uit . |
07-28-2010, 10:37 PM
Oke, made some good progress eventhought it takes more time than I thought. It it actually very enjoyable to do!
It is quite a job, especially because you need to line up for the bumper holder. Here some pictures, wil make some more tomorrow in day-light. @ Max, I do the welding indeed myself, you want to hire me ;-) ![]() ![]() ![]() |
07-28-2010, 10:45 PM
hoe ga je de binnenkant inwerken? zodat het niet van binnenuit die koker bijv weer kan gaan roesten
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
07-28-2010, 10:53 PM
To prevent it from insideout rusting I will use ML150(?) Tectyl. This is specially for inside chassismembers. It includes a little hose, this I can lead through some holes in the trunk floor.
07-28-2010, 11:59 PM
ah oke! thnx
09-15-2010, 10:34 AM
Okey, time for an update
While working on the car I found more and more rust and rust and rust. A lot worse than I had expected actually. I have been working hard on it and now all chassis rust is done. right chassis member front right side chassis member front right rear chassis member right sill rear behind bumper left rear chassis member left rear side chassis memebr left front chassis meber left front side member left sill left shocktower piece inside: right foot, behind rear seats (place where brackets from axle are mounted), underneath rear seat so as you can read i went around the car, more pictures of result will follow ![]() ![]() ![]() ![]() ![]() |
09-15-2010, 10:41 AM
Next up are the rear wheel arches. I am going to use the escort arches again. Last time I did not have my own welding machine yet and did not agree how the mechanic fixed it. I am, however, in doubt about how I can fix this best.
![]() I don`t have a better picture but the left side was dented, here I have cut away the top piece and restyled the inner side ![]() ![]() ![]() In the last picture you can see how I ended the chassis welding wich I will finisch when the new arch is on there |
09-20-2010, 05:58 AM
robokill Wrote:ja mux first bushing meet? Hebben we daar nog foto's van ?Hmmm, vast wel ergens.. moet ik es in de backup CDs gaan spitten... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-20-2010, 06:00 AM
Daniel,
Je bent die halve auto opnieuw aan het inmekaar lassen ![]() Maar super werk man! Schiet lekker op! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-28-2010, 01:19 AM
danielvanderwoude
hey men what is going on? i see that you got that baby nice..whell nice to meet you.. |
project "twin cam 16" another AE86... | fax0815 | 11 | 19,361 |
11-19-2011 09:05 AM Last Post: BOOMEX |
Twin-Cames 16 from switzerland movies.... P2 | Anonymous | 29 | 33,270 |
06-29-2010 11:44 PM Last Post: Anonymous |
Opex: AE85 3a-gze>>3a-gzte in progress | opex | 24 | 38,883 |
01-14-2010 06:09 AM Last Post: opex |
Mikzu's 4A-GZE project | Mikzu IV | 22 | 37,604 |
11-03-2008 04:11 PM Last Post: Jousi |
ae86_sr20 drift cam | ae86_sr20 | 32 | 34,060 |
01-01-2008 04:23 PM Last Post: ae86_sr20 |
