Corolla GT Coupe - Royalty Black
08-27-2015, 11:02 PM
Post: #201
Bit late but thats really weird.
is the iscv properly installed?
Is the white vacuum thingy for the map sensor installed correctly?
08-28-2015, 01:08 AM
Post: #202
It was a vacuum pipe really cut off! Solved.....
I just have the ISCV not working.... i can't cycle from cold start to idle.....
The pump is stuck somewhat on open.... Smile
I just idle for 1500.... when i close the air to the ISCV i can idle for like 900.... After that i can't do a cold start again..... Smile
Guess i'll have to buy one..
09-28-2015, 11:34 PM
Post: #203
It was about time to hit the tracks......
Last saturday was a great day! Finally the time to test my car!
The damn suspension sux! Koni Sport and Apex were great on the 110Hp range...
With the blacktop i need more.....
Some pictures....
[Image: AEU86 AE86 - Corolla GT Coupe - Royalty Black]
My girlfriend converted...
Pr0n!
And on the 26November we have more! Algarve circuit time!
10-02-2015, 01:48 PM
Post: #204
congratulations!
Rising Sun T
12-11-2015, 06:12 PM
Post: #205
Well.... 1000km's later.... the car started smoking and the 3rd and 4th cilynders don't look so good...
Still need to make a compression test to check my car up, but i think because it was stopped for a long time the piston rings aren't doing what they suppose to do....
Will spare my car from high revs and high mileage... and start building my spare parts a bit more...
As i checked i already got the contacts to rebuild the engine properly...
Will do it like properly and will change it all......
New oil pump,
New valve stem seals
New Headgasket
New piston rings
New engine bolts
New piston rings
The crankshaft and cylinders will be re-machined properly if needed.....
Just want a decent engine...
12-30-2015, 02:28 AM
Post: #206
Hi Pack, the Trueno is looking stunning, it's a shame that the engine began to fail after such a little mileage Banging head but I'm sure you'll have a more powerful & reliable motor once it's rebuilt and rocking again Thumbs up!
Btw, do you have in mind any specific setup for the suspension?
12-31-2015, 01:40 AM
Post: #207
headrush, thanks!
This thing with the engine was a low blow.... but i can get past it... soon it will roll again!
Yeps i have something on my sleeve.... I think i'm moving to BCracing and will overhaul them with bilstein material... 6Kg springs (Swift) in the front, 4.5Kg in the back
Cusco sways on both sides
Basically this is it...
12-31-2015, 08:08 AM
Post: #208
You might want have a look at Schockworks from Australia, would allow you to skip the overhaul part and they already come with the soft springs
12-31-2015, 11:06 AM
Post: #209
Or simply order BC Racing coilovers with 6/4.5KG springs. No need to modify them as they can be configuered as you want.
Daily Beater: Civic EG5
Work in progress Car: AE86
12-31-2015, 04:58 PM
Post: #210
If got bc racing in my car (5kg in the front and 4.5kg in the back)
I'm very happy with them.
grtz
  Gtsi-R red'n black coupĂ© Gtsi-R 147 151,635 02-03-2022 02:43 PM
  my 8a9 corolla GT coupe cloko 24 46,687 01-30-2012 05:17 AM
Last Post: Sambo
  My UK TE71 Corolla SR Coupe Finished.... japclassics 8 18,260 01-11-2011 02:12 PM
Last Post: Pacsker
  my 1984 red over black corolla gt davegtcoupe 3 11,197 10-12-2010 08:14 PM
Last Post: davegtcoupe
  RaceMinded satin black Toyota Corolla AE86 Levin Coupe RaceMinded 22 34,693 09-02-2010 07:25 PM
Last Post: Apolan
