Coil Spring Question ??
05-04-2010, 05:33 AM
I have some Tokico 5-way adjustable shocks on my AE86, but just have the stocks springs. I have played around with the adjustments, but most run on 5 (stiffest) setting even for daily drive since it feels the best. - It may be a little harsh at times, but I was thinking this might just be because of the springs. They are just he stock springs.
I was wondering how I should choose springs for the car. I don't care about lowering it, just curious if there is something that would complement the shocks better that was not too expensive. I see a lot of inexpensive D1 springs on ebay.
05-04-2010, 07:55 AM
Forget ebay D1 springs. Try a set of thicker swaybars, that should do the trick.
05-05-2010, 03:42 AM
NoHachi Wrote:Forget ebay D1 springs. Try a set of thicker swaybars, that should do the trick.
I will do sway bar and bushings later in the summer. Right now I was looking at doing springs since I am doing rotors and ball joints. Thought I would dive in further and remove the strut and replace the springs.
I think I definitely need a stiffer spring. - Would the D1 be a good spring over the stock springs? They said the are just like Tanabe's: http://cgi.ebay.com/ebaymotors/ws/eBayIS...MEWAX%3AIT
Also these D1 say a 1.8" drop, which seems like a lot. Has anyone used these springs?
What other adjustments or mods would I have to make if I bought some of these?
05-06-2010, 03:43 AM
Quick follow up to above post: What adjustments would need to be made, if any, for springs that would drop this much?
05-06-2010, 02:40 PM
juantonwan Wrote:Quick follow up to above post: What adjustments would need to be made, if any, for springs that would drop this much?
Traction Brackets at rear and Roll Center Adjusters at front.
  Coil charge time totta Crolla 0 970 01-23-2026 07:27 AM
Last Post: totta Crolla
  Smallport coil totta Crolla 2 4,017 08-12-2022 11:03 AM
  How to test coil with igniter DJexor 2 10,892 03-22-2018 10:01 AM
Last Post: Project D
  SOME 4AG valve spring specs oldeskewltoy 5 16,824 05-04-2015 01:17 PM
  clutch pedal return spring Eifelaner 2 9,400 09-06-2013 10:21 AM
Last Post: Apsogos
