Clutch types for AE86
09-06-2005, 01:21 PM
A friend with a 20V in his AE86, "killed" his clutch.
He asked me, I take a look here, I see no sticky, I say thats a chance...
Ok, lets make this a sticky for CLUTCES
What types of clutch (and brands) can be used in a normal AE86 with 4age?
What types of clutch (and brands) can be used in a modified AE with 4age?
What types of clutch (and brands) can be used in a modified AE with 4agZe?
And in more hurry, What types of clutch (and brands) can be used in a modified AE86 with 20V ITB?
[Image: AEU86 AE86 - Clutch types for AE86] http://www.jdmbits.com
09-06-2005, 01:54 PM
Well, there is a maximum size flywheel that will fit the t5 Bellhousing, and that is really the only limiting factor (along with the number of flywheel bolts maybe). I know for a fact that ae92 flywheels will fit, they are a little bit bigger on late model ae92 gti's (with 7-rib 4age).
A 20v on a t5 gearbox will most likely be using the stock bellhousing, so you're stuck to a certain maximum clutch diameter.
I dont know anything about most racing clutches, and have no experience with them myself. But from what almost everyone on club4ag is saying, the Illegal Garage clutches (sold by Max Misawa) are the best option for street performance and drifting. Those are very strong clutches that survive clutch kicks better then most other clutches, and are not to difficult to drive with. You get a complete set with pressure plate, bearing and install tool.
Max can tell you exactly what will fit your engine and requirements, or even make something custom for you.
Senna from this forum has one in his car right now, and I have bought other stuff from him before so you know he's trustworthy.
09-06-2005, 03:44 PM
How do one contact this Max?
09-06-2005, 03:47 PM
http://www.illegalgarage.com
Or try finding him on club4ag, he's on of the top posters there so it's never hard to find him.
09-06-2005, 08:15 PM
I heard somewere that you can coat your old clutch plate with new friction material which also has a higher friction coefficient (right?).
Anyone ever heard of this?Maybe interesting for mild tuning?
Real men race downhill
09-06-2005, 10:06 PM
1983 - 1987 AE86 --- 1987 (A) - 1990 AE92 GTi
have the same flywheel with 200mm clutchplate
1990 (B) - 1992 --- AE92 GTi has 212mm clutchplate with different flywheel.
I use an AE92 GTi -88 stock clutchplate with an TRD preassureplate right now
01-09-2006, 04:03 PM
you can use a 200mm clutch or 212mm clutch for the AE86 RWD T50 transmission
yes you can "coat" you clutch disk, its called rebuilding the clutch disk
you have to be very good at this to make it work properly
you guys are welcome to e-mail any time if you have any questions
(please no pm's)
My builder has built all types of clutches from roller coaster rides to million dollar classic indianapolis race cars (muesium type stuff)
Max
[email protected]
02-04-2007, 10:13 PM
i have a 1984 model trueno
have fitted to the car a Helix Cerametalic paddle clutch
as my car is a 1984 it has the 200mm flywheel
to use this clutch i needed the 212mm flywheel
it is a straight swap take the old flywheel out drop new one in
the clutch feels real good, there is a little bite despite being a paddle clutch
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
02-07-2007, 06:00 PM
I will be installing a Cusco clutch kit on saturday.
I'll post the feedback about it in this thread - It's a 3-piece kit with Cusco 5kg Flywheel, Pressure plate and Cusco "Copper Type" clutch plate.
http://www.perfectrun.com.au/real_size_i...clutch.htm
Has anybody here ever installed one of these kits?
If so, is there is anything special that needs to looked out for when installing these types of kits?
I'm pretty sure it should be standard procedure, just asking to be sure that it works out well in the end. Wink
02-16-2007, 06:54 PM
sup guys if you need a clutch
just send me an e-mail Smile
Max
[email protected]
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 5,391 07-25-2021 04:41 AM
  Anyone farmiliar with hks camshaft types for 4age? spill86 5 19,291 11-18-2017 11:36 PM
  Ae86 bulk head mod to fit hydrolic clutch? dinkers542 8 12,263 11-25-2014 09:21 PM
Last Post: dinkers542
  AE86 halfshaft types? TheGerman 6 14,004 11-27-2012 08:02 PM
Last Post: fax0815
  Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, dsrturbo 2 7,074 07-28-2011 10:51 AM
