Clutch burnt smell
08-18-2014, 09:33 AM
Clutch burnt smell
Hi all.
I own a TRD 2 way LSD on my Trueno. When i'm stopped and start to drive and turning together, i can hear my clutch disk swapping and burnt smelling. Why ? Is it because it's a 2 way diff and it blocks already the wheels when the car is moving ? |
08-18-2014, 09:42 AM
Clutch burnt smell
hi i think 2 way isnt drive to road u know its only for race
so when u are in race didnt care u noise but when are in road u hear everything thats why u hear this noise what is ur car ?? 2 way diff is nothing to do with clutch if i am correct |
08-18-2014, 11:28 AM
Clutch burnt smell
Burnt gear oil smell or friction material/brake type smell?
No, It'd be impossible to smell unless they were dry, the diff housing had a BIG vent and one wheel were was turning much more then the other. The oil would burn first and on a common 90degree turn, there's only 4-6 more turns difference between the inside & outside wheel, so not enough slippage & not enough speed to burn anything. 2 way is fine, it's from the factory exactly that way. So what! |
08-18-2014, 11:45 AM
Clutch burnt smell
My clutch is almost new and it smells friction material.
Something like braking the clutch. Envoyé depuis mon GT-I9100 avec Tapatalk |
08-18-2014, 03:28 PM
Clutch burnt smell
Are you sure it's not the brake calipers binding? Much more likely than the clutch burning.
08-18-2014, 03:36 PM
| Clutch burnt smell | |||
08-19-2014, 06:53 AM
Clutch burnt smell
Get outta the car & use your nose to locate the source.
So what! |
09-03-2014, 09:09 PM
Clutch burnt smell
(08-18-2014 03:36 PM)izanagi Wrote:(08-18-2014 03:28 PM)Ivan141 Wrote: Are you sure it's not the brake calipers binding? Much more likely than the clutch burning. just drive a little bit until you notice the burned smell, GENTLY feel if the rear calipers and disc are hot, if not i would not suspect the rear brake calipers. Real men race downhill |
09-04-2014, 10:54 PM
Clutch burnt smell
(08-18-2014 09:33 AM)izanagi Wrote: I own a TRD 2 way LSD on my Trueno. When i'm stopped and start All clutch type LSD's rely on the "wedging" action of the cam and ramps to create pressure on the clutch packs and lock the axles together more or less, depending on the load. A 2-way LSD is designed for racing type applications, and will have more aggressive ramp angles and some pre-load to ensure that it locks up early and firmly. This means that when you do a standing start, you can expect the LSD to lock. If you are making a turn at the same time (out of a parallel park for example), the locked up diff will try and skid the inside wheel. With wide rims and sticky tires, this can take quite a lot of effort. So more slipping of the clutch, and a few more revs are required. A new clutch plate, like new brake pads, has binder resins that need to burn off during the bedding in process, before the lining becomes fully effective. Moving at speed, the smell of the resins burning is swept away, but moving away from a park, or manouvering in a tight space, the smell will be noticeable in the car. It will go away after you have done a few hill starts and high rpm launches from the traffic lights Cheers... jondee86 |
09-04-2014, 11:04 PM
Clutch burnt smell
(09-04-2014 10:54 PM)jondee86 Wrote:(08-18-2014 09:33 AM)izanagi Wrote: I own a TRD 2 way LSD on my Trueno. When i'm stopped and start Thanks for the explanation. I've understood. Perfect.
| 4AGE - Engine Smoke and Smell | pack | 10 | 19,502 |
04-20-2017 05:06 PM Last Post: Bean |
| 4age Gas smell | ae86canarias | 4 | 10,917 |
07-02-2012 04:21 PM Last Post: ae86canarias |
| Fuel smell | totta Crolla | 4 | 8,698 |
06-03-2011 09:57 PM Last Post: totta Crolla |
| Clutch Master Cylinder and Clutch Slave Cylinder fitment? | christsang7 | 2 | 6,327 |
07-01-2009 07:48 AM Last Post: jondee86 |
| Problem: Soft clutch pedal - no clutch activation | dreja | 5 | 9,412 |
02-09-2006 11:27 PM Last Post: Denmark |
