Clear Lenses
09-04-2005, 12:57 PM
Clear Lenses
I've looked at a 350Z, I don't think they will fit. They look too round.
09-04-2005, 01:59 PM
Clear Lenses
Yeah, I 've thought of hat too.
Maybe if you sandpaper (how do you say that thing you re doing whith a sandpaper, anyway???) the iner side, it might fit... I meen, Kris fitted a straight one forgod sake danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
09-04-2005, 04:22 PM
Clear Lenses
Look what i've found.
09-04-2005, 08:14 PM
Clear Lenses
WHHHHAaaaaaaAAAAAAAAAAAAAAAAAAAAAAATTTTTTTTTTTSSSSSSSSS
this? edit (after the first shock): It looks like a civic one tuned to fit danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
09-05-2005, 11:30 AM
Clear Lenses
Sorry I missed this post guys, The 'wrap around' clear lenses are only available on the Mk1 S12, the facelift model doesnt have them
they are about 5cm tall and 30 cm long to the wraparound, if anyone wants any, i can ask around and try and get you a set if they are any good, PM me Terry still no 86 ________________________ |
09-05-2005, 11:42 AM
Clear Lenses
OH boy! You did fantastic job man.
These might fit! Kouki hatchi bumper is about 6,5 cm hight and 26 cm long untill the curve. So, with a little work, these should fit if THE CURVE fits! I dont know how can we check the curve but... can you check thje curve? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
09-05-2005, 11:46 AM
Clear Lenses
Errm how do you want me to check it? what measurments do you need?
I could pull one out and photo it from the top maybe? let me know what you need and Ill do it still no 86 ________________________ |
09-05-2005, 11:50 AM
Clear Lenses
Just checked, yup 26cm to the start of the curve and they are about 5.5cm high, looking at the 'small side' of the curve (side of the car, not the front) is 10 ish cm
09-05-2005, 11:56 AM
Clear Lenses
I dont want to put you in too much trouble man, you 've done enough allready!
Thought, the ideal would be to take one off an test fit it on a AE86 kouki levin bumper! But... as far as i understand there is no hachi near you... edit: so go and get yourself a hachi and try that :wink: :wink: :wink: danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
09-05-2005, 12:20 PM
Clear Lenses
nmwisima Wrote:edit: so go and get yourself a hachi and try that :wink: :wink: :wink: Im trying Im trying!!! Anyone want to lend me a Hachi, so I can test this for you all? still no 86 ________________________ |
| will the 0.5 mm HEADGASKET clear? | Apolan | 15 | 16,977 |
01-31-2008 01:48 PM Last Post: meshin |
| Swapping headlamp lenses | Sanity Clause | 10 | 12,087 |
01-17-2008 09:59 PM Last Post: Jezza_hr |
| Clear cam gear/timing belt cover | JonAE86 | 4 | 6,482 |
01-09-2006 07:12 PM Last Post: JonAE86 |
| Clear side turn signals and more. | jamiemirror | 3 | 5,710 |
02-02-2005 04:44 PM Last Post: jamiemirror |
![AEU86 AE86 - Clear Lenses [Image: AEU86 AE86 - Clear Lenses]](https://www.aeu86.org/sticker-banner-468.gif)
