Check connector?
01-25-2005, 09:13 AM
Check connector?
I can't locate check connector on my hachi. I suspect for two connectors covered by rubber, but I'm not sure because in 4age manual it should be square shape connector. Can somebody help me for this issue? Thx
Fun is not the straight line!
01-25-2005, 11:39 AM
Check connector?
If you have a zenki ae86 the look for a single loose yellow connector with a rubber cap on it...should be on the firewall behind the intake manifold.
A kouki ae86 would have a square little box that says diagnosis on it in almost the same location.
01-25-2005, 12:17 PM
Check connector?
Yes, there is a single loose yellow connector with a rubber cap on it with few terminals. Do you know which terminal I have to shortcut for:
1) Diagnostics?
2) BTDC set up?
I can only find description for the squared one.
01-25-2005, 02:57 PM
Check connector?
There should be a loose connector with only 2 terminals (of the 'female' type). I assume you have a 83-85 model then.
When you short the 2 terminals in the yellow connector the check engine light will give possible error codes and you can set distributor timing as well..it's all done with the same connector terminals bridged. I'll try to find a pic for you..
01-25-2005, 03:04 PM
Check connector?
Here's a lil artwork for you...enjoy!
01-26-2005, 09:59 AM
Check connector?
Thanks! You help me a lot. I'll try to do so.
Regards.
  Speedometer broke and check engine light sheppardpat47 19 3,536 10-02-2026 02:04 PM
Last Post: jomme_mega
  which connector is this ditn 7 11,602 07-27-2015 11:24 AM
Last Post: pack
  help, puzzled by the radio connector Bean 4 8,600 11-17-2014 11:32 PM
  Engine Check Light at High RPM Super86 8 12,846 11-03-2014 11:03 AM
Last Post: Super86
  the connector saga (please help everyone) Bean 8 13,342 06-23-2014 01:13 PM
