Carb conversion but what is this and how ?
03-14-2016, 10:38 PM
Well the reason for this post is this
http://www.86garage.com/blog/archives/220
Check the distributor further down.
Using a sr20 distributor and cop setup.
Really interesting!
Because I am trying to find a solution when blocking the distributor port
and have a cop setup with a msd system I stumbled upon this.
Is the signal usable with msd computer ? And can i even get this adapter needed ?
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
03-15-2016, 12:06 AM
Actually I found that part possible to buy from cby directly, my japanese skills are not dull yet,
http://www.cby.jp/hachiroku/parts.html
this adapter is way overpriced 450euros
no one can make one of these in europe ? Wink Wink
03-15-2016, 10:32 AM
Oda's setup is NOT a carburator but an Hayabusa ITB (fuel injected)
[Image: AEU86 AE86 - Carb conversion but what is this and how ?]
(and it's not a SR20 distributor but an SR20 cam angle sensor + RB coils)
You can convert your original distributor in a CAS only if you want:
http://www.sq-engineering.com/20v-4age-d...r-302.html
and for the coil on plug part, you will need a proper ECU.
03-15-2016, 03:26 PM
Or use 4agze cas distributor.
I happen to have one for sale Smile Smile
03-15-2016, 08:08 PM
I'll be using a SR20DET CAS on my build powered with my Haltech. Is it necessary? No. I have a 4AGE 24+2 distributor which can be used just as well with little modification. If an MSD can run it I can't tell as I don't know enough about MSD gear.
AE86 ex-daily
05-24-2016, 08:48 AM
(03-15-2016 03:26 PM)ditn Wrote:  Or use 4agze cas distributor.
Do you still have it? Im interested Tongue
  20v Blacktop conversion.... Mylesmck 0 1,671 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 5,535 02-08-2024 10:30 AM
Last Post: r.ave
  AFM to Map Conversion ps13michi 3 5,889 01-06-2022 10:34 AM
Last Post: ps13michi
  Engine starts/revs but no idle GenkiMotors 17 13,193 11-20-2021 04:12 AM
Last Post: GenkiMotors
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 9,469 11-05-2021 08:17 PM
Last Post: gh0st
