Can't get my car started!
09-11-2013, 09:57 AM
*allow me to throw an obvious suggestion out there:
CHECK THE ECU FOR BLOODY FAULT CODES! FABRICA MI DIEM, PVNC! |
09-11-2013, 02:55 PM
Assuming that you did everything in order of the posting then the engine would not start after you fitted new camshaft oil seals ?
I'm not sure it is possible to change the seals without removing the cams so I will assume also that you removed the camshafts ? Now that we can see the full picture I would say your problem lies with a timing issue, either cam timing and / or ignition timing. An analogue brain in a digital World |
09-11-2013, 06:36 PM
phill 92 Wrote:I may have to try swapping the EFI relay if people seem to believe this works ?? Don't believe me, i'm a bot, not human. Also it's a big PITA to try a different relay, it's much easier to replace everything else.
Keeping the AE86 alive! |
09-16-2013, 02:24 PM
Had a play on the weekend and noticed there was a broken cable on a multi clip from the 3 wires that go from the igniter/coil into the dizzy, pulled the plug out and connected the wires and it started. Let it run for about 15 mins and it ran perfectly.
Revved it a little and it kept cutting out, so I tightened the battery terminals and it was fine. The next day I went to start it and it wasn't having anything! I will replace the suspect wiring and hope for the best! Thanks. |
09-16-2013, 05:22 PM
Dodgy earth?
I had mine running last week, took stat off box housing, forgot to put earth back on, jumped it, it ran, turned off then was completely dead... I have had serious issues with my battery terminals recently as well... |
09-16-2013, 05:23 PM
totta Crolla Wrote:Assuming that you did everything in order of the posting then the engine would not start after you fitted new camshaft oil seals ? You can replace the camshaft seals without removing the cams. I made the mistake of re-fitting my front plate then finding I hadn't replaced the seals. Took the end cam caps off and put seals on, quite easy really. |
| Can Wing Mirror Glass be Replaced? | chrisae86 | 4 | 2,637 |
10-05-2025 11:09 PM Last Post: chrisae86 |
| Can you convert your 86 back too the original state? | gh0st | 7 | 5,014 |
04-25-2022 04:25 PM Last Post: gh0st |
| Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 12,392 |
| Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 13,250 |
09-08-2021 12:48 PM Last Post: Ryo |
| can i just slam a oem turbo on it ? | MC_JP | 3 | 7,220 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
