Camshafts... what is your desire?
03-21-2013, 09:20 PM
As many of you know I've been working on clearing space @ a local race shop.
Well, they have BOXES of old camshafts... there are picking through the lot to see which ones are either repairable, OR grind-able to new dimensions...... And here is where you come in... What is wanted? Would you prefer repaired 288+ duration 9.5+mm lift cams?? OR... Would you prefer these cams be ground to 272 or less durations, with lifts under 9mm??? expected price on these should be under $500 for a pair So what say you????? Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-22-2013, 06:48 PM
If you can get me a pair of camshafts delivered to the UK for less than £400 @ 250-260 duration max lift 9.0mm i'd be happy - highly unlikely though!
03-22-2013, 07:08 PM
$500 = ~£330 and I doubt the shipping cost more than £70 / ~$105
So less than £400 sounds realistic to me ![]() |
03-22-2013, 07:20 PM
272 with 10,5mm lift perhaps
![]() What make is it, and how used are they? Restoring my AE86, all the way... Going JDM style ![]() http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
03-22-2013, 07:38 PM
These are all Atlantic type cams so all are over 280 duration. Some are TRD.
03-22-2013, 07:54 PM
Another thought....
what about selling them as "repairable" they may have a damaged journal, or lobe. In this situation they could sell for $100-$125 per cam Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-23-2013, 03:14 AM
288 with 9.5mm lift
03-23-2013, 08:08 AM
So a set of 280 with about 10.5mm lift would be possible?
Now my question is that to much duration when I plan to use a SC14 with 1mm oversize valves, ported head, larger injectors 2,5" exhaust? With a MAX of 8500 RPM... Restoring my AE86, all the way... Going JDM style ![]() http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
03-23-2013, 02:41 PM
Not an expert but 8500rpm and 280 duration sounds just right.
Not sure if you need that much lift with supercharger and OS valves. |
How to add photos to your posts | banpei | 2 | 8,556 |
01-17-2022 10:31 PM Last Post: banpei |
what is your opinions on these head gaskets... | CHOPKIN2 | 5 | 7,524 |
04-09-2018 05:29 PM Last Post: mad.matt |
KE70 - need your help! | zemosh | 2 | 6,445 |
03-19-2015 07:42 PM Last Post: willy |
About to order Camshafts | Alex170984 | 5 | 7,568 |
06-18-2013 12:54 PM Last Post: Alex170984 |
Need your help,looking for a rallcar thats looks like this | ditn | 17 | 23,593 |
04-11-2013 07:13 PM Last Post: ditn |
