Cams for a stock 4age 16v
10-09-2008, 08:54 PM
Post: #51
Ivan141 Wrote:Wasnt there someone who mentioned that 3SGE lifters will also work on a 4age (under-bucket shims!)?
yup but never seen it in an engine. Besides I don't have spare 3sge lifters Tongue
10-09-2008, 10:19 PM
Post: #52
tolisspi Wrote:My engine is 4age bigport tvis
My project includes:
1- 4age bigort head with toda 272 10,3 lift.
- Custom made or toda shims kit for underbucket shims rebuilt.
- Adjustable cam gears of toda.
- Valve spring of toda too.
2- 4agze bottom end but i replaced the pistons of 4agze with 4age smallport toda pistons 82mm 20 pin.
- Crankshaft rods ect of 4agze.
- Compression ratio 11,3:1 with OEM headgasket.
3- Piggyback ecu. But which brand is better?
Now is allready the bottom end and im waiting the head to rebuilt.
Which will be the result?
What do you think?
The bad thing is that i have oem exhaust system
If all be fine, future plans:
- Standalone ecu
- Throttle body of black top.
Still very interessted in the answer. What will a 272° 10.3mm Toda Setup produce? And how will the lift afect idle, and rpm range (8mm, 9.5mm, 10.3mm...)
10-09-2008, 10:54 PM
Post: #53
I dont know mate yet. I have to repair the head first and ll see.
Also i order shims kit of TODA and
ARP head stud
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Cams for a stock 4age 16v]
10-27-2008, 09:47 AM
Post: #54
I'd like to dig out that thread again, because of some personal interesses:
Where is the peak HP for following cams, without dialing with a adjustable pully.
256
264
272
288
10-27-2008, 11:41 AM
Post: #55
MartinS, it is impossible for anyone here to answer that question. Camshafts are not only specificated in duration. Lift is very important.
288 duration camshafts at 7.9mm lift (Toda) are able to produce peak horsepower at 7500rpm. And this number will vary accordingly to the rest of the engine setup.
Robokill, I'm running 7M-GE 300cc's injectors and I get 80% injector opening with my setup. 304 7.5mm TRD camshafts on ITB's.
I've just bought a pair of Kent camshafts with 298 duration and 9.4mm of lift and I'm almost sure I'll have to raise fuel pressure to keep injector opening rates low.
You can have 250cc's injectors, for sure, but you have to raise fuel pressure a lot!
Best regards
10-27-2008, 11:49 AM
Post: #56
Yeah, I understand but a aprox. idea where to aim for?
I'm quite fancy to see a dyno on 272 10.3mm Toda. Where would you guess Peak HP? 8000, 8500?
10-27-2008, 11:58 AM
Post: #57
Yes, it will be around that range I think!
10-27-2008, 12:55 PM
Post: #58
that depends on loads of things .... with stock intake manifold and exhaust i don't think peak power will be that high
10-27-2008, 11:19 PM
Post: #59
Here is mine on the dyno made 133@ the wheels7650 rpm.
4AGE,HKS 264 cams,TVIS removed Kakimoto exhaust
http://uk.youtube.com/watch?v=krMns5rOTJ0
10-28-2008, 08:11 AM
Post: #60
But i think with adjust cam gears that you can adjustable the in which rev get the power, medium or high revs, isnt it?
  Digital speedometer on stock dashboard FanIsHere 0 2,539 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 4,404 11-24-2021 04:26 PM
Last Post: apardal
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 24,730 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 32,386 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,380 11-09-2020 10:51 AM
Last Post: totta Crolla
