Camber angles
01-01-2009, 01:07 PM
Camber angles
Can anyone help explain these camber angles please.
(I don't have a "degree" button on this computer so I will write "degree" where appropriate) cross camber measured at: -0 degree 25' How much actual difference is this between sides ? Are they the same or does the 25' have some significance. Thanks for any help and happy new year to you all TC
01-01-2009, 04:24 PM
Camber angles
25' means 25 minutes.
60 minutes equals 1 degree. So 25/60*100 = 0.42 degrees Therefore total cross camber is 0.42 degrees. |
01-01-2009, 04:37 PM
Camber angles
would you consider this enough to worry about ? One side being -1d 29' the other -1d 04' An analogue brain in a digital World |
| What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 19,883 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
| Camber adjustment vs original struts | Lt86 | 9 | 13,858 |
05-07-2015 09:45 PM Last Post: zenki |
| back camber of CBY | roiz86 | 5 | 12,534 |
03-24-2013 02:00 PM Last Post: roiz86 |
| Camber plates | harkes | 10 | 18,115 |
02-08-2013 03:28 PM Last Post: pack |
| Camber Question? | J-86 | 4 | 7,246 |
11-11-2012 10:41 PM Last Post: J-86 |
TC
