Camber angles
01-01-2009, 01:07 PM
Camber angles
Can anyone help explain these camber angles please.
(I don't have a "degree" button on this computer so I will write "degree" where appropriate)
cross camber measured at: -0 degree 25'
How much actual difference is this between sides ? Are they the same or does the 25' have some significance. Thanks for any help and happy new year to you all Hurray! TC
01-01-2009, 04:24 PM
Camber angles
25' means 25 minutes.
60 minutes equals 1 degree.
So 25/60*100 = 0.42 degrees
Therefore total cross camber is 0.42 degrees.
01-01-2009, 04:37 PM
Camber angles
would you consider this enough to worry about ?
One side being -1d 29' the other -1d 04'
  What is normal and low caster in Cusco camber plates?? T_AE86 9 19,798 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Camber adjustment vs original struts Lt86 9 13,781 05-07-2015 09:45 PM
Last Post: zenki
  back camber of CBY roiz86 5 12,480 03-24-2013 02:00 PM
Last Post: roiz86
  Camber plates harkes 10 18,030 02-08-2013 03:28 PM
Last Post: pack
  Camber Question? J-86 4 7,216 11-11-2012 10:41 PM
Last Post: J-86
