Camber adjustment vs original struts
05-04-2015, 07:35 PM
Hi everyone,
I have a question regarding camber adjustment with original dampers and springs.
When I had the aligment checked we noticed the camber on one side was out of spec. This is causing the steering wheel to vibrate at a certain speed. I wouldn't say it is excessive but it annoys me and may cause wear on bearings and steering components.
Can someone tell me how to sort this problem? I want to keep my current suspension setup (stock). Can I install a certain type of adjustable camberplate? Which ones would you recommend and do I need to combine it with a set of upper hat camber plates or is this not necessary?
Thanks in advance for the advice Wink.
05-04-2015, 08:35 PM
Camber will not cause any vibration, only something out of balance, like the wheel or out of round like the hub or rim or tire.
So what!
05-04-2015, 09:11 PM
I didn't think so either but I'm running out of options. Wheels and tires have been balanced and they are as good as new.
05-05-2015, 12:43 AM (This post was last modified: 05-05-2015 12:45 AM by allencr.)
Unfortunately, New doesn't matter at all.
Check that the hub, the rim and the tire don't have any runout.
Stick your head out the window to actually see which one/s are hopping or wobbling, front & rear.
So what!
05-05-2015, 10:08 AM
Side to side camber differences can sometimes be fixed by adjusting the engine crossmember, moving it across to the side with the low camber angle.
Are you using stock wheels ?
05-05-2015, 02:36 PM
No, I'm using 15" compomotives Smile.
05-05-2015, 05:04 PM
First thing then is to check that they are centred on the hubs as per the stock rims.
05-05-2015, 09:15 PM
Are you using center rings(centreerringen) with the wheels?
ハチロク
[Image: AEU86 AE86 - Camber adjustment vs original struts]
05-07-2015, 12:24 PM
Oh god, I can't believe it did not think of this Undecided.
No, I don't believe the car has 'center rings' installed so the rim might indeed bit a little bit off center when mounted.
Since you seem to speak Dutch, Zenki. Do you know a good place to buy/order them in Belgium or the Netherlands?
05-07-2015, 09:45 PM
I bought mine from a uk shop on ebay. Most of the parts i buy come from usa, uk or japan.
ハチロク
  Clutch Slip - Adjustment DMC 3 2,237 04-25-2025 11:29 PM
Last Post: DMC
  Handbrake adjustment discs? DMC 8 4,569 03-10-2024 08:08 PM
Last Post: DMC
  Can you convert your 86 back too the original state? gh0st 7 5,499 04-25-2022 04:25 PM
Last Post: gh0st
  Restoring original pizzacutter center caps banpei 17 13,756 06-24-2021 10:58 PM
  What is normal and low caster in Cusco camber plates?? T_AE86 9 18,107 01-07-2016 02:56 AM
Last Post: Deuce Cam
