Clutch Slip - Adjustment
04-24-2025, 12:15 AM
I parked my AE86 up last summer and didn't take it for a drive until a couple of weeks ago. I noticed the clutch is now slipping, as soon as I put my foot down at all it just revs up.
It has an Excedy Paddle competition clutch and before parking it up it drove perfect.
Does anyone know what I could do to check? Or anyway it could be adjusted.
Fluid reservoir is full.
04-24-2025, 10:55 AM
You need to check for oil leaks around the bellhousing.. sounds like a leaking main crankseal to me.
04-24-2025, 12:35 PM
Not likely, but the rubber hose to the slave cylinder, if it is old and hard could be restricting return flow to the slave cylinder. Do you have a return spring on the clutch arm. Is the slave cylinder push rod preloading the clutch arm. Or is the M/C rod not returning far enough in the master cylinder to release pressure. If none of these check out, you are probably going to have to pull the trans and inspect the clutch.
04-25-2025, 11:29 PM
Thanks for the replies!
(04-24-2025 10:55 AM)Ivan141 Wrote:  You need to check for oil leaks around the bellhousing.. sounds like a leaking main crankseal to me.
I had a look but I couldn't see any leaks. I did have a leaky sump last year, but that was sorted and maybe done 1000 miles after that with no issues.
(04-24-2025 12:35 PM)Dave W Wrote:  Not likely, but the rubber hose to the slave cylinder, if it is old and hard could be restricting return flow to the slave cylinder. Do you have a return spring on the clutch arm. Is the slave cylinder push rod preloading the clutch arm. Or is the M/C rod not returning far enough in the master cylinder to release pressure. If none of these check out, you are probably going to have to pull the trans and inspect the clutch.
I'll try and get a look into those suggestions tomorrow.
  Handbrake adjustment discs? DMC 8 5,947 03-10-2024 08:08 PM
Last Post: DMC
  Camber adjustment vs original struts Lt86 9 13,682 05-07-2015 09:45 PM
Last Post: zenki
  Clutch adjustment heshan 10 20,981 11-09-2011 10:08 AM
Last Post: jondee86
  How to adjust camber on the front using standard adjustment? JDMitch 14 28,988 06-17-2011 04:55 PM
Last Post: Andrax
  DIY/How-to: E-brake adjustment for GT-S rear ends. assassin10000 3 20,445 12-12-2010 11:47 PM
Last Post: Hachi
