Camber Question?
11-08-2012, 10:53 PM
Camber Question?
Can anyone help I've installed coilovers on my 86 with adjustable front top mounts with both set on maximum negative camber but its seems like i've got more negative camber on one side. How do I correct this?
11-09-2012, 12:11 AM
Camber Question?
Usually, the camber plates have two sets of holes. One set gives more
adjustment than the other. Make sure you have both sides set up on the
same four holes... either the inner or outer set.
Cheers... jondee86
11-09-2012, 03:18 AM
Camber Question?
Just get it properly (3D laser)aligned they will get it even and don´t run silly camber! You are probably not aware that the top mounts don´t need to be at the same position at both sides, in 99% they will be slightly different, cause thats the point in having them, to get the alignent even!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
11-11-2012, 10:41 PM
Camber Question?
Thanks for your input guys Smile
  What is normal and low caster in Cusco camber plates?? T_AE86 9 19,890 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Camber adjustment vs original struts Lt86 9 13,873 05-07-2015 09:45 PM
Last Post: zenki
  back camber of CBY roiz86 5 12,543 03-24-2013 02:00 PM
Last Post: roiz86
  Camber plates harkes 10 18,127 02-08-2013 03:28 PM
Last Post: pack
  How to adjust camber on the front using standard adjustment? JDMitch 14 29,371 06-17-2011 04:55 PM
Last Post: Andrax
