Camber Question?
11-08-2012, 10:53 PM
Camber Question?
Can anyone help I've installed coilovers on my 86 with adjustable front top mounts with both set on maximum negative camber but its seems like i've got more negative camber on one side. How do I correct this?
11-09-2012, 12:11 AM
Camber Question?
Usually, the camber plates have two sets of holes. One set gives more
adjustment than the other. Make sure you have both sides set up on the same four holes... either the inner or outer set. Cheers... jondee86 |
11-09-2012, 03:18 AM
Camber Question?
Just get it properly (3D laser)aligned they will get it even and don´t run silly camber! You are probably not aware that the top mounts don´t need to be at the same position at both sides, in 99% they will be slightly different, cause thats the point in having them, to get the alignent even!
11-11-2012, 10:41 PM
Camber Question?
Thanks for your input guys
| What is normal and low caster in Cusco camber plates?? | T_AE86 | 9 | 18,661 |
01-07-2016 02:56 AM Last Post: Deuce Cam |
| Camber adjustment vs original struts | Lt86 | 9 | 12,627 |
05-07-2015 09:45 PM Last Post: zenki |
| back camber of CBY | roiz86 | 5 | 11,502 |
03-24-2013 02:00 PM Last Post: roiz86 |
| Camber plates | harkes | 10 | 17,081 |
02-08-2013 03:28 PM Last Post: pack |
| How to adjust camber on the front using standard adjustment? | JDMitch | 14 | 27,069 |
06-17-2011 04:55 PM Last Post: Andrax |
