Brake master cylinder
05-31-2010, 05:33 PM
An old thread but a goodie.
May I just add, after bench bleeding the master cylinder, when you reinstall it, make sure the hard lines have something connected to the other end so your brake fluid doesn't drain out all over the floor........ Fortunately after staring dumbly wondering where the puddle was coming from, I had time to bung up the line with plastic plugs before the reservoir emptied.
In my defense, it was down to 6 degrees celsius here at midnight. Brrr.
  Bigger brake master cylinder options Koen 10 2,713 01-08-2026 03:12 PM
Last Post: r.ave
  4AGE cylinder head plug removal Ivan141 5 5,071 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 19,276 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 9,679 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 6,636 05-29-2015 01:23 AM
Last Post: oldeskewltoy
