[Bolt Torque] Bluetop head x Redtop block
09-18-2008, 03:07 PM
Currently overhaulin an engine for a client, thing is he already bought the car with a redtop block and bluetop head.
How much torque should in the head bolts? Kinda confused and dont want to mess this up. Thank you for your time
09-18-2008, 05:33 PM
i guess it depends, do the torques differ from engine to engine?
There's a site out there with torque specs for engines from an AE92 (redtop i presume?)... [s:a01cf5d775] I'd say, depending on where the screw actually screws (or are both parts threaded?) go for a middle ground, or just torque it up to the bottom part spec (redtop block specs)[/s:a01cf5d775] (edit: robokill's suggestion sounds way more logical than mine) then again, you might ruin the bluetop if the specs are way outta line. The 4AGE manual, is that for a bluetop only? (it seems for AW's as well, they're sideways... but also bluetop?)
09-18-2008, 11:10 PM
I will bolt it like a regular Bluetop:
300kg , +90º, +90º Thanks Pardal for the help cavey thank you for your help too
09-18-2008, 11:29 PM
As the head of the 4age is bigport always bolt it to those specs. The lower block is cast iron and won't crack while the head can!
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 3,388 |
| Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 16,567 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 18,475 |
| 4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 108,134 |
05-05-2019 04:03 AM Last Post: Rocker100 |
| Cam Cap Bolt Snapped!! | Alex170984 | 1 | 5,638 |
06-08-2018 01:17 PM Last Post: Ivan141 |
![AEU86 AE86 - [Bolt Torque] Bluetop head x Redtop block [Image: AEU86 AE86 - [Bolt Torque] Bluetop head x Redtop block]](http://img845.imageshack.us/img845/1082/capturar01.jpg)
