Bodywork in 3 steps
11-22-2005, 05:55 PM
Bodywork in 3 steps
Looks cool! I thin I've seen this Trueno before, it looks sweet in this paint configuration... Anyway, I'd go red with black bumpers.
11-22-2005, 07:51 PM
Bodywork in 3 steps
i agree with max_ae86 - too many pandas running loose. Big Grin
11-29-2005, 11:47 AM
Bodywork in 3 steps
What do you think?
Those 5mm plates around rear struts should be strong enough Thumbs up!
Fun is not the straight line!
11-29-2005, 12:29 PM
Bodywork in 3 steps
max_ae86 Wrote:What do you think?
overkill
steel will broke up in the weakest place anyway.
continue work in that way and u will loose weight balance also Smile
11-29-2005, 08:27 PM
Bodywork in 3 steps
hachi could always use some celulite in her but =) better weight distrib. only have to be careful to balance it left /right.
11-30-2005, 12:15 AM
Bodywork in 3 steps
Whoa... You're doing an excellent job. Thumbs up!
Think it will hold. Wink
[Image: AEU86 AE86 - Bodywork in 3 steps]
12-01-2005, 10:10 AM
Bodywork in 3 steps
Well, I’m not as fast as Zax, regarding car rebuild but…
…no more rusty holes at the back! I hope 0,5 kg more at the back will make no difference. In stead of 3mm I put 5mm plates. It’s only 2mm thicker plate.
Still, plenty job to go.
12-01-2005, 10:59 AM
Bodywork in 3 steps
hMM,
In the rear tower ,there is two plates .
There is regular 1mm plate,and a 2mm!
So it i think that what you have made here is weaker then OE
Regards,
Skassa
Any fool can go fast in a straight line.
VEMS Blacktop 4AGTE20V 272hp/350nm
"""www.turbotoys.dk"""
12-01-2005, 11:07 AM
Bodywork in 3 steps
Denmark Wrote:hMM,
Regards,
Skassa
But surely, better then a rusty hole, which I had before :wink:
12-01-2005, 01:38 PM
Bodywork in 3 steps
max great effort! are you doing the work yourself?
  Ivan's coupe: bodywork is done Ivan141 676 1,203,006 08-07-2024 08:46 AM
