Bluetop camshafts on...
11-25-2005, 02:03 AM
They fit Evil Evil Evil
[Image: AEU86 AE86 - Bluetop camshafts on...] http://www.jdmbits.com
11-25-2005, 11:14 AM
Goodmorning!
Let's continue plz.
So cam's of the bluetop fit my GZE, from 232 to 240o...
Are they bolt on?
Do I need adjustable c/gears?
Do I need a piggy-back or something?
11-25-2005, 11:30 AM
nmwisima Wrote:Goodmorning!
Let's continue plz.
1. Are they bolt on?
2. Do I need adjustable c/gears?
3. Do I need a piggy-back or something?
1. yes
2, 3 will help but not required
11-25-2005, 11:57 AM
Any chance that they make a difference, cause they are only little wilder than the stock...
11-25-2005, 12:16 PM
little wilder little more valve lifting ...
a little here ... alittle there ... and you get some more hp !
Don't you agree?
11-25-2005, 01:20 PM
I wouldnt be to confident about gaining much horsepower with bluetop cams.. The timing has to be right too y'know..
Boosted cars react better to cams that have less overlap in their profiles..
NA engines do better with some overlap since that allows exhaust pulses to suck fresh fuel mixture in. Running a boosted engine on NA cams will make the fresh mixture get blown out the exhaust because the valves are still opened for a bit. Dunno how this applies to supercharged cars, but my guess is that it's not going to make much of an improvement.
11-25-2005, 01:30 PM
if you want more hp, why not just upp the SC pulleys ratio? you got forced ind. go the easy way.
11-25-2005, 02:16 PM
Allready got bigger pulley and closed blow-off.
Engine now runs at 0,8-0,9 bar (instead 0,55) and raises to 1,1 bar at 5.500 with 5th gear. Evil
I m aksing cause this might be a cheap way (since Aloimonos allready has the cams) to get some power adding the OBX header i 'm about to buy soon :wink:
11-25-2005, 03:54 PM
You could offcourse try to adjust the camgears to adjust the opening and closing times for less overlap using bluetop camshafts.
11-25-2005, 06:20 PM
nmwisima, how much is she making now?
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 14,332 04-19-2021 10:08 PM
Last Post: Hanzo
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 16,246 02-10-2020 06:39 PM
Last Post: Power_uP
  Bluetop on turbo leon205gti 7 10,104 09-20-2016 09:17 PM
Last Post: leon205gti
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 46,013 08-21-2016 04:51 PM
Last Post: ray
  Bluetop AFM with air filter izanagi 4 8,849 04-29-2016 07:29 PM
Last Post: oldeskewltoy
