B Tune Swift Front & Rear Springs
05-30-2006, 02:26 PM
You could try having custom springs wound with a number of very closely spaced windings. This will give you an area on your spring with very low springrate that will let the car sit a bit lower but still keep the spring captive at full extension. The trouble is that you would need a lot of these windings if you want 8kg/mm, leaving the part of the spring that does all the work with little travel.
Messages In This Thread
[] - Ivan141 - 05-30-2006, 11:39 AM
[] - max_ae86 - 05-30-2006, 12:01 PM
[] - Ivan141 - 05-30-2006, 12:27 PM
[] - max_ae86 - 05-30-2006, 12:53 PM
[] - NoHachi - 05-30-2006, 01:30 PM
[] - max_ae86 - 05-30-2006, 01:50 PM
[] - Ivan141 - 05-30-2006 02:26 PM
[] - max_ae86 - 05-30-2006, 02:34 PM
[] - max_ae86 - 05-30-2006, 02:47 PM
[] - Ivan141 - 05-30-2006, 03:05 PM
[] - max_ae86 - 05-30-2006, 03:53 PM
[] - max_ae86 - 06-05-2006, 10:27 AM
[] - max_ae86 - 06-06-2006, 09:40 AM
[] - SYM - 06-08-2006, 06:45 PM
  HKS valve springs totta Crolla 3 4,572 05-25-2022 10:24 PM
  Springs from other vehicles?? FanIsHere 16 20,412 05-17-2016 09:12 AM
Last Post: FanIsHere
  S13 Front brakes in AE86 rear heshan 25 35,892 02-01-2014 12:37 PM
Last Post: heshan
  3rd door support gas springs (stay) - worn out max_ae86 5 8,307 09-01-2013 03:20 PM
Last Post: Jezza_hr
  Valve springs length Vil 4 7,731 04-04-2013 07:41 PM
