Aram's 3SGE Beams Levin Coupe
08-20-2013, 07:58 AM
Post: #621
the oilpan is quite LOW? is there any room to go up or need totan new steel part to get it little higher?
08-20-2013, 12:44 PM
Post: #622
Thanks Dave!
Yes the oilpan is very low, 7cm. First on the list is making some protection for it. :-) |
08-20-2013, 05:31 PM
Post: #623
nice work
08-20-2013, 05:59 PM
Post: #624
Aram Wrote:Thanks Dave! I must look what i can do whit my self.. best would be make the lower steel-pan my self. WHIT 3-4cm lower but lot wider.. But i must look up to it.. WAY to low be without protection |
08-20-2013, 08:20 PM
Post: #625
08-20-2013, 08:25 PM
Post: #626
08-20-2013, 09:45 PM
Post: #627
corolla4agze Wrote:Aram Wrote:Thanks Dave! I like what Fer Monti has done: https://www.facebook.com/media/set/?set=...514&type=3 That will probably be a good solution. |
08-21-2013, 06:45 AM
Post: #628
yep. i have looked same pictures. Lot better to get few cm from stock. Even that much it must help lot. Its sit so low whitout
08-22-2013, 08:10 PM
Post: #629
Aram Wrote:Thanks Dave! very welcome ! with the oil pan i'd assume you should be able to get bigger motor mounts or make some to raise it a bit to help or no? |
08-22-2013, 08:18 PM
Post: #630
i think there is not much room whit Stock hood and beams "valve cover"
| ae86 racecar with beams engine | bakonick | 148 | 194,070 |
| Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 108,340 |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 18,978 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 189,516 |
| AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 684,553 |
