Aram's 3SGE Beams Levin Coupe
12-30-2011, 10:48 PM
Post: #401
Hachiville? I think we all want to live there, don't we?
![]() Those Luxembourg always have the best towns. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
01-03-2012, 08:46 AM
Post: #402
Hi Aram,
have you done anything yet with the tail shaft? Do you have the actual lenght? Cheers, Vener |
01-03-2012, 12:42 PM
Post: #403
I am also interested in how you modify the tail shaft, Aram.
I have the original shaft weld together with the 6 speed U-Joint. Everything installed but no balance yet. BTW, I came back From Aust and my engine is running already, still need some tuning before it can really drive. Cheers! |
01-03-2012, 11:40 PM
Post: #404
Hi guys,
I did not do anything to the tail (prop?) shaft yet. The part that goes into the 6 speed is to short, they cut it off halfway through the joint. I need to find another shaft that fits, but I don't know from which cars they fit. :S @kd, Good to see it is running. |
01-04-2012, 12:18 AM
Post: #405
Aram Wrote:Hi guys, Lexus IS 200 Has exactly the same shaft as Beams one. it MIGHT even work from IS with different engine (not only 2.0l one) I bought full shaft including hang up bearing and second half of it that goes to the diff - for 60 pounds shipped to my doors from UK
Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
01-04-2012, 12:50 AM
Post: #406
That is information!
![]() I presume I need the manual gearbox shaft, or doesn't it matter? |
02-27-2012, 12:27 AM
Post: #407
Ok, so you guys don't think the project is dead, here is a little update...
Progress is slow though that is a pitty, but alot of thing are nearing completion. First up the tank, I put the Walbro pump in, which involved a bit of tweaking of the wires. The standard connectors did not fit the Walbro, luckily a collegue found the exact same connectors and we had a tool to fit them properly, so in the end it sat factory style. ![]() New pump on a new bracket in a new tank: ![]() ![]() ![]() Under the car: ![]() Then this arrived from the UK, an orignal RS200 propshaft: ![]() Fitting for fitment: ![]() No idea how much play I should keep in the setup I went with 15mm, anyone know if this is ok? Anyway, it is welded up now, but not finished yet as it needs new bearings, did put it under the car already, sits pretty good imo: ![]() ![]()
02-27-2012, 12:48 AM
Post: #408
Radiator work is still in progress, I got me a Mitsubitshi Space wagon shroud with fan to mate to the Scenic radiator.
It was the closest to fitting remotly ok, but it involved work. The width was almost ok, but as you can see it was to short in heigth, well that is almost fixed but no pics yet. ![]() Here you can see the gap, the mounting brackets are also custom made: ![]() I was working on the feul lines that run from the chassis to the tank under the car, I felt they were hanging to loosely, so I made 3 stainless steel brackets of which the middle is fastened to the chassis. And some plastic dividers: ![]() ![]() ![]() ![]() ![]() ![]() ![]() The feul line in the engine bay was to short to my liking so I made another one, plus I made the return line. You can also see the bracket we made for the pressure regulator. Only line to be fitted now is the one from the filter to the fuel line, then the feul system is done!! ![]() ![]() ![]() The only brake lines to made are the ones on the rear axle, I began with the one that comes from the chassis to the axle. I made a looping in it to have enough play for the movement of the axle when driving, but the exhaust is going to be thruogh there aswel, what do guys think? ![]() More later. |
02-27-2012, 04:18 AM
Post: #409
Super Sweet, excellent build.
02-27-2012, 07:07 AM
Post: #410
the cover plate on the front tail shaft should be about 5mm out from the back of the gear box cover on the extension housing on the box as motor and box does move same with rear end
| ae86 racecar with beams engine | bakonick | 148 | 207,118 |
| Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 118,604 |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 20,863 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 203,968 |
| AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 720,855 |
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0163.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0164.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0166.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0224.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0205.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0230.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0249.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0247.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0218.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0184.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0187.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0188.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0191.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0214.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0275.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0276.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0266.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0267.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0262.jpg)
![AEU86 AE86 - Aram's 3SGE Beams Levin Coupe [Image: AEU86 AE86 - Aram's 3SGE Beams Levin Coupe]](http://i29.photobucket.com/albums/c281/Tranquill/Hachi%20Roku/IMAG0270.jpg)
