Anti roll bars
04-04-2006, 09:24 AM
Anti roll bars
Hi
I have recently lowered my car 40mm and are using yellow koni. How ever I want to eliminate some more body roll and are looking for new anti roll bars. Fensport has a wide range but which ones should I go for? Are there any drawbacks in choosing the "heavy duty"?
- Niels, Denmark
04-04-2006, 09:38 AM
Anti roll bars
A big anti roll bar will really stiffen the car up, but there are drawbacks:
Cornering capability for street use will be compromised.. the anti roll bar will cause both tires to skip when you drive over irregularities in the road, thus causing a loss of grip. When you have less anti-roll bar effect the suspension operates a bit more independent on both sides and can handle these irragularities better.
Personally I think big anti roll bars are more fit for track use, but then you could also go for stiffer springs. For street use a slightly bigger pair of rollbars is a worthwhile option to reduce roll while retaining the comfort of softer springs. Also keep in minde that the rollbars will effect the tendency to over/understeer, if you only change the front one you might be introducing more understeer.
04-04-2006, 11:04 AM
Anti roll bars
Thanks! The car is a DD, and have to be able to cope with bumpy city roads. Which is the best comprimise - the TRD? I'm planning on replacing both front and rear ARB, and ofcourse installing a adj. panhard.
- Niels
  AE86 roll center adjusters for Carina nyberrg 9 16,461 06-16-2015 02:45 AM
Last Post: roman
  Roll centre adjusters totta Crolla 9 16,334 10-21-2013 06:05 PM
Last Post: Deuce Cam
  why do you use "roll center ajuster"? leckter 15 25,614 02-07-2012 07:04 PM
  Front Anti Roll Bar for Beams Swap KD2229 5 9,190 09-20-2011 10:04 AM
Last Post: Aram
  TE71 roll cage totta Crolla 3 7,317 02-04-2011 05:43 PM
Last Post: corolla4agze
