Alu crank pulley.. are they good?
03-29-2010, 03:45 PM
Agreed. And it is also worth remembering that, with the exception of a
few premium models, modern cars are not designed for extended periods
of operation at maximum output. Typical driving conditions only allow for
short bursts of full power (overtaking), followed by longer periods of
running at part throttle.
Extended operation at full power will exceed the cooling capacity of heat
generating parts, engine, gearbox, brakes and differential. I have seen it
many times in 6 hour endurance races for standard production cars. Even
on cars carefully prepared for racing, after 2 or 3 hours the failures will
begin to occur. Overheated engines with blown head gaskets, seized
gearboxes and brakes no longer working.
That is why dedicated race cars are built with stronger components, and
designed from the ground up to handle the loads imposed by racing
conditions. Its a balancing act Smile Not just a question of adding parts at
random, and hoping that they will give more performance without making
a problem somewhere else.
Cheers... jondee86
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 2,470 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  Alu thick core radiator fitment Gtsi-R 5 4,826 01-26-2022 01:28 PM
Last Post: Gtsi-R
  Can you identify this wheels? Will they fit AE86? Ryo 8 13,781 09-08-2021 12:48 PM
Last Post: Ryo
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 23,231 08-16-2018 01:36 AM
  D2 Coilovers any good? heshan 18 31,773 04-04-2017 02:40 AM
Last Post: hachirokkos
