All the 4age from ae86 are with 40mm crank journal ?
11-21-2010, 09:34 AM
Kose i have starting one projekt with one 4age end this has 40mm crank journal .
I want too puting in this motor 4agze pistons(42 mm C.J.)
I have 2 4age more ,kan be the others with 42 mm C.J.?
Thanks!
11-21-2010, 10:06 AM
I've seen about 10-12 4age engines from AE86 and only one was with 42mm C.J. It was from the last year, 1987. You should recognise if you have 3 or 7 rib engines, and if you have 7rib you have a chance (but not 100%)
11-21-2010, 10:57 PM
ZDoman Wrote:I've seen about 10-12 4age engines from AE86 and only one was with 42mm C.J. It was from the last year, 1987. You should recognise if you have 3 or 7 rib engines, and if you have 7rib you have a chance (but not 100%)
Thanks wery much but wath its 3 or 7 rib engines?
11-22-2010, 12:30 AM
you can use a 42mm crank, providing you match it with the correct Rods and Pistons...
Early (most) AE86 came with 40mm, later AE92 came with the 42mm crank, and on to the later 4age AE101/11 Levins...
11-22-2010, 02:22 AM
google for 4age 7-rib block and the pictures will tell you the difference.
7-rib has 4 additional reinforcement ribs on the side of the block--> stronger, later engine
11-22-2010, 06:54 AM
http://www.club4ag.com/faq_and_tech_page...0Block.htm
Cheers... jondee86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 24,031 08-16-2018 01:36 AM
  crank 6 bolt flywheel DJexor 5 10,353 12-05-2016 08:21 AM
Last Post: d3nso
  Something of interest to all suspension number crunchers Bean 1 5,232 01-05-2015 10:29 AM
Last Post: Uzelac
  4ac crank on 4age! Ghetto 7 12,608 12-05-2014 10:42 PM
Last Post: Uzelac
  Crank pulley without harmonic damper Jan Pedersen 21 29,419 05-21-2014 09:50 AM
