Air temp. sensor placement
01-14-2011, 11:21 PM
Just need confirmation that placing the air temp sensor here will work ok.
[/img]Obviously I will need to drill a hole in the intake. Or maybe right down by the neck of the air filter but sill on the intake pipe of course. http://86life.wordpress.com/ |
01-15-2011, 01:24 AM
That is exactly where I put my intake sensor, and it worked fine. Use
the rubber grommet that comes out of the AE92 airbox. Cheers... jondee86 |
01-15-2011, 03:41 AM
Thanks! Would it make any difference whether I put it on the intake end or the filter end of the pipe?
01-15-2011, 03:47 AM
Nope... same air both places. Anywhere in the intake duct that you
can reach with wiring will do. Cheers... jondee86 PS: You driving your car yet ? |
01-15-2011, 03:52 AM
Very soon. Would have done the cert last week but guy was on holiday. Hopefully organize something this coming week. I have a carbon bonnet coming shortly but hopefully it won't require a cert.
| Air conditioning R134A swap | sheppardpat47 | 7 | 3,049 |
10-13-2026 10:21 AM Last Post: seefuchs |
| map sensor cheating? | fdsjakl890 | 8 | 4,571 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 8,734 |
01-07-2024 11:36 AM Last Post: CCB |
| Lambda sensor wiring | sam3007 | 10 | 10,092 |
| Air Cleaner Assembly | Hama86 | 7 | 13,271 |
10-29-2018 03:28 AM Last Post: Hama86 |
[/img]
