Ae92 water pump same as ae86????
12-04-2007, 10:40 PM
Just as it says..
Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
12-04-2007, 10:52 PM
according to the EPC it's not the same
AE86 part# 16100-19095 AE92 (4age) part# 16100-19115 if you need one, you can get it there pretty cheap http://www.markenautoteile.de |
12-04-2007, 11:28 PM
I have put a AE92 front part in to AE86 rear part. They will fit together.
Whole pump assy is different from the rear. Here is a AE92 water pump ![]() and here is AE86 water pump with AE92 front part ![]() Oh, I almoust forgot. Front parts has different lenght. AE92 front is couple of mm shorter, so if you use a AE92 front part with RWD pulleys, you need spacer. Quote: "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
12-05-2007, 06:03 PM
If you use an AE92 pulley you wont need a spacer to make it line up.
The main reason that the AE86 pump is longer is that it has a bigger bearing. Probably designed this way because the AE86 has a mechanical fan attached to it..this increases the stress on the bearing. I have been using an ae92 pump for a long time with no problems, but I've seen pictures of pumps where the front had broken off completely, so it's up to you if you want to use one or not. FABRICA MI DIEM, PVNC! |
12-05-2007, 10:16 PM
thanks everyone.
I wonder isnt it better then to have a electric waterpump. Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
| 20v BT - which oil pump? | Mylesmck | 4 | 5,836 |
| Fuel pump issue | DJexor | 11 | 11,190 |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 11,606 |
12-06-2017 06:48 PM Last Post: Bean |
| fuel line hose from the pump | Wikizz | 4 | 8,397 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
| 20v conversion water relocation | izanagi | 1 | 7,956 |
06-15-2016 09:45 AM Last Post: banpei |
![AEU86 AE86 - Ae92 water pump same as ae86???? [Image: AEU86 AE86 - Ae92 water pump same as ae86????]](http://i33.photobucket.com/albums/d61/Kleemola/Corolla%20AE86/Moottori/4A-GElohkoosittainkasattuna4.jpg)
![AEU86 AE86 - Ae92 water pump same as ae86???? [Image: AEU86 AE86 - Ae92 water pump same as ae86????]](http://i33.photobucket.com/albums/d61/Kleemola/Corolla%20AE86/Moottori/Kuva032.jpg)
