Ae86 Horsepower Calculation....
08-29-2009, 06:23 AM
i took the time to figure this out......i hope this will help you guys out in your projects.... 4ac's - 2jz's
these are (( rounded figures )) in what you need in Horsepower in 1/4 mile times.... The Elapse Time Method: This method uses the weight of the car and the time it took that car to travel 1330 feet (ΒΌ mile). The formula is: hp = weight / (ET / 5.825)3 avg ae86 body coupe/hatch 2400lbs avg fat/muscle person 200lbs = 2600lbs ((( these times are based on a 2600lbs car if its lighter or heavier your HP will change))) and yes variables to apply equipment,weather, & how power is applied... 7.0 sec = 1498 hp 7.5 sec = 1218 hp 8.0 sec = 1004 hp 8.5 sec = 837 hp 9.0 sec = 705 hp 9.5 sec = 599 hp 10. sec = 514 hp 10.5 sec = 444 hp 11.0 sec = 386 hp 11.5 sec = 338 hp 12.0 sec = 297 hp 12.5 sec = 263 hp 13.0 sec = 234 hp 13.5 sec = 209 hp 14.0 sec = 187 hp 14.5 sec = 169 hp 15.0 sec = 152 hp 15.5 sec = 138 hp 16.0 sec = 125 hp 16.5 sec = 114 hp 17.0 sec = 105 hp 17.5 sec = 096 hp 18.0 sec = 088 hp 18.5 sec = 081 hp 19.0 sec = 075 hp 19.5 sec = 069 hp 20.0 sec = 064 hp
Reppin' the old skool....Drive Drift Dream ![]()
08-29-2009, 02:06 PM
You do realize that tires, suspension setup, engine build up, chassis, drivetrain, gearbox(Ratios, automatic gearbox turbine ect.) and about everything else also has an effect on your 1/4 time? Not even mentioning the driver. Cant really just count on the horsepower mate.. Just use a dyno man..
08-29-2009, 07:18 PM
yes i do realize that weather, equipment and how power is applied comes into play......
but if you sit there and do the math....the figures will come close..... as a matter i ran 14 w/ my GZE and my hp is around 180's...so its pretty damn close this method is not the most accurate but a pretty good base line in horse power....so people can figure what is needed when you got figures ...you come & talk actual weight trap speed elapsed time Reppin' the old skool....Drive Drift Dream ![]()
08-29-2009, 09:53 PM
ae86driftmaster Wrote:avg ae86 body coupe/hatch 2400lbs avg fat/muscle person 200lbs = 2600lbs What? Either every specs page and my car's papers are really way off, or you might have mixed up something there. |
08-30-2009, 01:19 AM
how much do you and car weigh at? and how fast you gone the track?
| Final drive calculation. | Aram | 31 | 43,485 |
12-24-2014 03:08 PM Last Post: Uzelac |
![AEU86 AE86 - Ae86 Horsepower Calculation.... [Image: AEU86 AE86 - Ae86 Horsepower Calculation....]](http://i40.tinypic.com/20itljq.jpg)
