Advice needed on parts!
03-01-2013, 08:42 PM
Right I finally got my 86 off of the road for a bit of a freshen up, the top of my list is getting the diff rebuilt. I am planning to get the diff out myself and send it to a specialists to be rebuilt and then re-install myself.
I've done a little bit of research and have read its pretty simple other than removing the half shafts. Basically what I wan't to know is what parts/seals would you replace for good measure along the the way? Also any tips wouldn't hurt! Thanks. |
03-01-2013, 11:28 PM
Replace all gaskets.. Toyota sell a complete gasket kit for the rear axle that has pretty much anything you need.
The only other seals to replace are in the pumpkin, and I assume your having that done buy the specialists you mentioned. FABRICA MI DIEM, PVNC! |
03-02-2013, 12:06 AM
When the time comes to replace the complete diff unit into the axle casing
put the big round gasket onto the diff unit not the axle casing :wink: An analogue brain in a digital World |
03-02-2013, 03:00 PM
Thanks guys, just been to Toyota and ordered a gasket set for the rear axle £5!
Is there any parts like bearings (non diff related as i assume my diff builder will tell me what i need here) that aren't ridiculous money that would be a good idea to purchase? Thanks. |
03-02-2013, 09:39 PM
Wheel bearings are the only ones left outside the pumpkin, and they are silly money. Good thing they last quite a while normally.
Brake advice - master cylinder | mannix20vt | 12 | 16,658 |
Engine advice needed | spill86 | 14 | 18,200 |
09-15-2015 10:43 PM Last Post: spill86 |
coilovers advice | robotype | 23 | 25,795 |
05-21-2013 10:18 PM Last Post: Jan Pedersen |
few issues after last drift days, advice needed | fax0815 | 3 | 5,391 |
08-26-2011 08:33 AM Last Post: jondee86 |
KE70 Tuning Advice! | Allexz | 13 | 20,810 |
11-20-2010 01:55 PM Last Post: Allexz |
