Adjustable Panhard Rod Bar
07-09-2010, 07:18 PM
Hi there
I think someone posted a method of setting up the adjustable panhard rod in this forum, but I can't find now... Can anyone help? |
07-09-2010, 07:51 PM
best place to measure is from the brake disk to the chassis frame
280z '75 audi S4 B5 '99 KE25 '71 |
07-09-2010, 07:55 PM
Then what do I do?
07-09-2010, 09:55 PM
you measure and shorten or lengthen the panhard on the adjustable bit accordingly untill the measurements are even. Best done with a pit as that way you can roll the car back and forth between measurements to be sure the adjustment has settlet (not necessary if you see results before)
AE86 ex-daily |
07-10-2010, 10:56 AM
If you have a lift, the best place to do your measurements from are the 4-Link pickup points. You want the wheels to be at an equal distance to those.
07-10-2010, 02:22 PM
There are so many way to do it. I read the AE86 Owners Bible, it even said you should measure from the drain holes to anti roll bar brackets
07-12-2010, 04:42 PM
Its easy to do – Drive the car between 2 gate posts.
Standing behind the car. If the car is lowered you will probably need to move the car body over to left and the axle over to the right. Attach a ratchet strap around the left rear towing and then around 1 of the gate posts. Attach another ratchet strap around the right rear wheel and around the other gate post. Disconnect the panhard bar. Then ratchet each of the straps to pull the body and axle inline. Measure off the arch initially and then when you close find 2 fixed points between the axle and the chassis to get it bang on. Once done, adjust the Panhard to the correct length and bolt back into place. ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
| Bash bar for zenki trueno bumper | gh0st | 3 | 4,687 |
02-08-2023 10:50 PM Last Post: Ivan141 |
| Question on Rod Bearings | mister86 | 3 | 6,403 |
03-19-2020 03:46 AM Last Post: oldeskewltoy |
| What bar is it? | FanIsHere | 7 | 10,948 |
10-20-2018 12:14 PM Last Post: FanIsHere |
| Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 26,916 |
| Adjustable steering column | 4000GT | 6 | 11,778 |
07-12-2012 08:15 AM Last Post: 4000GT |
![AEU86 AE86 - Adjustable Panhard Rod Bar [Image: AEU86 AE86 - Adjustable Panhard Rod Bar]](http://i57.photobucket.com/albums/g239/N2AE86/memberbanner1jpg.jpg)
