AE86 rear axle weight
03-04-2013, 10:43 PM
No prob, actually, once you add wheels and tires, the rear axle sits right at 100kg unsprung weight. So it really just depends on what anyone is trying to lift.
03-29-2024, 11:18 AM
Reviving this thread as I'm about to install a Feroza rear axle on my 86.
Confirming that OEM late/kouki/thicker/25mm shafts/axles weight 11,3kg without bolts.
[Image: AEU86 AE86 - AE86 rear axle weight]
Daihatsu Feroza/Rocky LSD rear axle detailed weighting
1. Each shaft/axle (converted PCD to 4x114,3): 7,20kg => 14,4kg for both
2. LSD differential, crown, pinion and pumpkin: 22,70kg
3. Axle/diff housing (no oil): 18,50kg
So the Feroza/Rocky axle without brakes, panhard, swaybar etc weights 55,60kg in total vs the 86 axle which according to you weights 46kg. That's 10kg added weight.
I will take the same measurements for the AE86 axle as soon as I remove and disassemble it.
Follow: The story of my AE86
  Axle width totta Crolla 1 3,391 10-24-2023 12:20 PM
Last Post: FanIsHere
  light weight Flywheel filh 9 11,335 02-05-2018 05:20 PM
Last Post: filh
  Rear axle options Dino86 13 20,088 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 5,325 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 13,051 10-18-2016 11:50 AM
Last Post: fantapants
