AE86 gearbox??
09-27-2007, 12:23 AM
AE86 gearbox??
Looking at getting a change to my knackered gearbox, been looking at changing to the sierra box.
Has anyone done this to their own car or know of anyone that has done this to any other car and what the strength of the box is like compared to the T50?
Or does anyone know of any good T50 boxes on the market just now?
Regards Scott Thumbs up!
09-27-2007, 08:13 AM
AE86 gearbox??
As I understood the Sierra box is one of the most widely used gearboxes for uprating any car. But I haven't heard anybody about swapping one inside a hachi though.
[Image: AEU86 AE86 - AE86 gearbox??]
09-27-2007, 09:14 AM
AE86 gearbox??
I have use a Escort´s "big" gearbox in 2T-G with aluminium middleplate between gearbox and 2T-bellhousing.
I used a 2T`s flywheel, Escort´s clutchplate and 2T-clucth cover.
I can take a pictuer from it, I still have it.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
09-27-2007, 12:43 PM
AE86 gearbox??
banpei Wrote:As I understood the Sierra box is one of the most widely used gearboxes for uprating any car. But I haven't heard anybody about swapping one inside a hachi though.
I have just heard of this uprate not long back and was curious if anyone else had actually done this. My gearbox is beyond repair and this seems like the only option i have at the present time. Fensport sell a bellhousing for connecting it to the 4-AGE and the uprated clutch, i've managed to find a place that sells re-conditioned 1600 boxes as well.
09-27-2007, 09:06 PM
AE86 gearbox??
Hi, I am running a sierra type 9 'box.
Here is some info:
A bellhousing is available, Raw engineering do one but it is expensive and is likely to need modification. An RM sport one is what you need, I believe this can be used with both sizes of flywheel but is worth checking.
I know where a used RM bellhousing is for sale.
You will need to fit a different sized spigot bearing to the crank, use Raw engineering for this.
Use a Toyota clutch cover and an MGB clutch plate (200mm)
A modification will need to be done to the release bearing, boring out the Toyota one I think.
You will also need to modify the rear gearbox mount. I believe Gartrac can do this for you.
The propshaft will need to be fitted with a Ford end to fit the gearbox, this will mean a modified prop.
The gearlever hole will need a slight mod.
Is it worth it ? Type 9 gearboxes are ten a penny and quite strong. The only downside is that first gear is a little short in my opinion. I have a new Quaife type 9 ready to fit.......
2.8 capri boxes have better ratios but the input shaft is too long, this can be shortened quite easily.
hth
09-28-2007, 03:41 PM
AE86 gearbox??
rotational spare Wrote:Hi, I am running a sierra type 9 'box.
Here is some info:
hth
Cheers for that info thats helped quite a bit Thumbs up!
I've been able to source pretty much all of the parts already, i'll pass this info on to the garage thats going to be doing the work just so they can have a look.
Regards Scott Smile
09-30-2007, 08:42 PM
AE86 gearbox??
Getting closer......
http://www.aeu86.org/viewtopic/t50-to-az...ues/t/4283
The link below has the same basic info... but I've been updating that more recently....
http://forums.club4ag.com/zerothread?id=830&page=1
Dan -
10-30-2007, 08:37 AM
AE86 gearbox??
Does anyone else have anymore info or pics about putting a Type 9 in the corolla? I've been wanting to do it for my rally car.
Wow, I could have sworn I had an account here... I guess I'm the new guy Sad
10-30-2007, 09:12 PM
AE86 gearbox??
I'm getting it done just now...the garage thats doing it seemed to think it shouldn't be too difficult to do. I'll be going along somepoint this week to have a nosey so i'll give you their opinions on how its going.
11-03-2007, 01:31 PM
AE86 gearbox??
haha....good...the sort of thing i was thinking of doing to my corolla!
great stuff! ill have a read bout it all!
cheers, adam Hurray! Respect!
  SR20DET (S13) gearbox shifting issues in AE86 heshan 8 15,083 07-22-2014 01:07 PM
Last Post: heshan
  MR2 clutch in an AE86 gearbox megabob 8 13,067 10-14-2009 06:00 PM
Last Post: megabob
  4agze > MA71 W5x gearbox > ae86 Diff - How? Xaerob 8 10,664 03-26-2008 09:37 AM
Last Post: Xaerob
