AE86 Rear Brake options.
02-25-2008, 11:28 AM
Most of original rear calipers are non-functional due to age, rust and dirt.
I prefer to use better ones + big brake option at the cost of rebuild + little more money spent.
Also keep in mind that this car use 276mm fronts + 4-pot calipers so 257mm rears are match. If you like - you can add sub-$50 Willwood brake bias regulator also.
Stock brake master works, the feeling is different. AE82 1.6 (even SOHC) use a little bigger diameter for brake master and is bolt-on for AE86 (at least LHD). You can calculate new brake fluid volume required for 4-pots, I tried in the past and result was <5% increase.
Messages In This Thread
AE86 Rear Brake options. - hachirokuGTV - 12-06-2007, 09:24 AM
RE: AE86 Rear Brake options. - izanagi - 04-27-2016, 10:48 AM
RE: AE86 Rear Brake options. - izanagi - 08-27-2016, 11:01 PM
[] - parrot - 12-06-2007, 10:21 AM
[] - jamiemirror - 12-06-2007, 11:26 AM
[] - parrot - 12-06-2007, 01:36 PM
[] - hachirokuGTV - 12-06-2007, 08:20 PM
[] - megahopi - 12-08-2007, 06:44 PM
[] - r.hellenbrand - 01-10-2008, 05:29 PM
[] - filh - 01-11-2008, 03:24 AM
[] - nzae86 - 01-11-2008, 08:44 AM
[] - NoHachi - 01-11-2008, 09:10 AM
[] - filh - 01-11-2008, 06:47 PM
[] - hachirokuGTV - 01-11-2008, 11:02 PM
[] - The Doctor - 01-12-2008, 12:05 AM
[] - jamiemirror - 01-12-2008, 04:48 PM
[] - nzae86 - 01-13-2008, 03:01 AM
[] - improvedae86 - 01-13-2008, 07:17 AM
[] - manipula - 01-13-2008, 07:30 AM
[] - brawnie - 01-13-2008, 11:46 AM
[] - improvedae86 - 01-13-2008, 10:16 PM
[] - seb - 01-15-2008, 08:43 PM
[] - jamiemirror - 02-22-2008, 11:25 AM
[] - Mux213 - 02-22-2008, 01:22 PM
[] - jamiemirror - 02-22-2008, 01:57 PM
[] - Mux213 - 02-22-2008, 02:14 PM
[] - AZNWOKZ - 02-24-2008, 08:23 PM
[] - jamiemirror - 02-25-2008 11:28 AM
[] - XJS - 02-25-2008, 01:51 PM
[] - jamiemirror - 02-26-2008, 11:58 AM
[] - frass_2k4 - 03-21-2008, 01:33 AM
[] - delazy - 07-28-2008, 03:09 PM
[] - jamiemirror - 07-30-2008, 11:38 AM
[] - Uzelac - 05-12-2009, 12:50 AM
[] - robokill - 05-12-2009, 10:14 AM
[] - speed-inc - 05-12-2009, 10:16 AM
[] - filh - 05-14-2009, 12:27 AM
[] - Lajoosh - 11-02-2009, 06:23 PM
[] - NoHachi - 11-02-2009, 07:28 PM
[] - Lajoosh - 11-02-2009, 08:02 PM
[] - filh - 11-02-2009, 11:01 PM
[] - Lajoosh - 11-03-2009, 07:42 AM
[] - Lajoosh - 11-03-2009, 06:57 PM
[] - Lajoosh - 11-04-2009, 12:03 AM
[] - filh - 11-04-2009, 12:41 AM
[] - KGC210 - 01-02-2010, 12:22 PM
[] - filh - 03-02-2010, 12:11 AM
[] - Lajoosh - 03-02-2010, 01:13 AM
[] - NoHachi - 03-02-2010, 09:40 AM
[] - filh - 03-05-2010, 05:18 AM
[] - nunoturbo - 03-05-2010, 05:15 PM
[] - NoHachi - 03-05-2010, 06:00 PM
[] - filh - 03-07-2010, 02:16 AM
[] - Lajoosh - 03-07-2010, 10:13 AM
[] - filh - 03-10-2010, 12:30 AM
[] - Lajoosh - 03-10-2010, 08:43 AM
[] - filh - 03-12-2010, 10:07 PM
[] - filh - 09-16-2010, 10:53 PM
[] - NoHachi - 09-17-2010, 08:22 AM
[] - [Walaki]D`Lair - 09-17-2010, 07:36 PM
[] - filh - 09-21-2010, 11:07 PM
[] - Jimmi The Kid - 02-28-2012, 10:56 PM
[] - Eifelaner - 03-16-2013, 03:12 PM
[] - ditn - 03-16-2013, 03:39 PM
[] - filh - 03-16-2013, 07:08 PM
[] - Eifelaner - 03-16-2013, 09:28 PM
[] - filh - 03-17-2013, 01:23 AM
  Bigger brake master cylinder options Koen 10 3,057 01-08-2026 03:12 PM
Last Post: r.ave
Thumbs Up ITB filter options mister86 1 5,335 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 37,886 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 15,949 01-24-2018 02:25 PM
  Rear axle options Dino86 13 19,821 01-08-2018 10:19 PM
Last Post: ditn
