AE86 Rear Brake options.
01-13-2008, 07:17 AM
Is that MA45 disc 250mm + ?
Another convo nearly the same size as S13 258mm , S13 rear discs fit the JDM diffs with center locator fitted and the caliper spaced out to suit the diameter difference. ![]() ![]() Other options are corona 280mm complete with the internal alloy hand brake backing plates and girlock caliper. Fitted to T series t18 or ra60 diff housing. Alot lighter set up than any steel mounting ae86 rear set up. ![]() also 910 bluebird is nearly the same brake package as the corona with alloy caliper and backing plate. ![]() both corona and bluebird depending on caliper use the same pad and caliper , also the same as holden commordore in aus. if going five stud you can use the S15 disc with S13 caliper or maybe with spacer ae86 calipers. This set up also still fits inside 15" rims and maybe a few 14". Just don't expect the small pad area of those calipers to really handle track use for more than a few laps. ![]() z32 or r32 rear only fits inside 16" rims but done with all alloy parts makes for a big disc 280x22mm and twin piston caliper with the weight of the other set ups
| Messages In This Thread |
AE86 Rear Brake options. - hachirokuGTV - 12-06-2007, 09:24 AM
RE: AE86 Rear Brake options. - izanagi - 04-27-2016, 10:48 AM
RE: AE86 Rear Brake options. - izanagi - 08-27-2016, 11:01 PM
[] - jamiemirror - 12-06-2007, 11:26 AM
[] - hachirokuGTV - 12-06-2007, 08:20 PM
[] - r.hellenbrand - 01-10-2008, 05:29 PM
[] - hachirokuGTV - 01-11-2008, 11:02 PM
[] - The Doctor - 01-12-2008, 12:05 AM
[] - jamiemirror - 01-12-2008, 04:48 PM
[] - improvedae86 - 01-13-2008 07:17 AM
[] - improvedae86 - 01-13-2008, 10:16 PM
[] - jamiemirror - 02-22-2008, 11:25 AM
[] - jamiemirror - 02-22-2008, 01:57 PM
[] - jamiemirror - 02-25-2008, 11:28 AM
[] - jamiemirror - 02-26-2008, 11:58 AM
[] - jamiemirror - 07-30-2008, 11:38 AM
[] - [Walaki]D`Lair - 09-17-2010, 07:36 PM
[] - Jimmi The Kid - 02-28-2012, 10:56 PM
| Bigger brake master cylinder options | Koen | 10 | 3,794 |
01-08-2026 03:12 PM Last Post: r.ave |
| ITB filter options | mister86 | 1 | 5,571 |
12-06-2020 10:44 AM Last Post: Bean |
| AE86 starter options | max_ae86 | 12 | 39,029 |
07-28-2019 08:17 PM Last Post: harkes |
| AE86 rear suspension options 2018 | Alex | 9 | 16,577 |
01-24-2018 02:25 PM Last Post: mad.matt |
| Rear axle options | Dino86 | 13 | 20,745 |
![AEU86 AE86 - [Image: AEU86 AE86 - ]](http://img50.imageshack.us/img50/8987/s13reardisconjdmae86difmj1.th.jpg)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](http://img144.imageshack.us/img144/2856/s13reardisconjdmae86difoo1.th.jpg)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](http://img50.imageshack.us/img50/4107/harleysdiff009oz4.th.jpg)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](http://img50.imageshack.us/img50/6084/rearbrakesif8.th.jpg)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](http://img519.imageshack.us/img519/3854/p1010857jw1.th.jpg)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](http://img519.imageshack.us/img519/9018/z32rearbrakes2qv0.th.jpg)
