AE86 Rear Brake options.
07-30-2008, 11:38 AM
Post: #31
http://www.galfer.es/asp/home.asp
Nissan Primera P10 2.0i 16V (for example):
Quote:Brake discs
Ref: DFA581R Technical characteristics
Altura total 45
Diámetro 258
Diámetro interior 68
Espesor DFA 10
Espesor DFA mínimo 9
Nº Tornillos 4
Par de apriete 10
Quote:Make Model Engine Since Untill 5. Rear disc
NISSAN PRIMERA (P10) 2.0i 16V 1993 1996 DFA581R
NISSAN PRIMERA (P11) 2.0i 16V (14" wheels) 1996 1999 DFA581R
NISSAN PRIMERA (P11) 2.0i 16V (15" wheels) 1996 1999 DFA581R
NISSAN PRIMERA (W10) 2.0i 16V Station Wagon 1990 1996 DFA581R
05-12-2009, 12:50 AM
Post: #32
Just ain't sure if i'm right.
These Nissan Primera rotors fit perfectly or need some work done on rear end ?
05-12-2009, 10:14 AM
Post: #33
they should fit but because the diameter increases you need to change the caliper. So then you would still need to change both before you have any effect.
05-12-2009, 10:16 AM
Post: #34
There are also FC3s and R32 rear kits from Japan.
They come with all necessary parts.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
05-14-2009, 12:27 AM
Post: #35
I bought the rear Primera rotors . they fit without problem , but the center hole is larger than the ae86 .
I did that to have the rear caliper upgraded with VW Golf caliper .
you can't keep the rear ae86 caliper .
It 's a cheap upgrade , but did not succeed to do it for now
Trying to have more information . I know the brake plate must be 180° flipped , but there's not enough room to fit caliper support, between disc and plate (even flipped)
Hoping to have help about that mod
Phil
Filh
Save the RWD cars
11-02-2009, 06:23 PM
Post: #36
Dear sirs! i read at some places including here that VW golf 4 brakes and nissan primera disks fit the 86 rear axle perfect. im through many sites and broken links about this topic and yet i didnt find accurate informations about this. Im not an expert about the brakes and also cant afford myself to test and try it myself. should i use front or rear caliper of the golf 4? front or rear disc of the primera and which year model?
photos would help alot!
for the front im planning to use the t3 wilwood big brake kit. do i need to upgrade my brake master cyl, if so, what should i use that wont inwolve tons of modifications on the brake booster?
my 86 is 1985 eu-spec (german?), non-ps, 5speed manual and has zenki rear axle.
11-02-2009, 07:28 PM
Post: #37
Hiya Lajoosh, see the post directly above yours..apparently its not 100% certain that this works.
To be honest..in a well setup car the front of the car is doing 80-90% of braking, so max 20% left for the rear. This is the only energy you need to disspate..in theory that should be possible with the std brakes. Just mix and match rear pads to get the correct F/R balance and temp range.. (actually, that might be the biggest problem, finding a set of rear high temp pads that work and fit)
I've also upgraded to the wilwoods and plan on monitoring rear brake temps with temperature sensitive paint.. I honestly don't expect any problems, but would love to hear if any of the experienced racers here have had other experiences.
11-02-2009, 08:02 PM
Post: #38
the problem is my calipers and discs are in so bad condition that for me it doesnt worth refurbishing them. thats why i spend a little more money and do big brake conversion on the front and also the rear. filh's post didnt say more than he used the rear discs of that primera which i still dont know anything more. Smile
neither know the caliper is taken from the front or the rear of the golf4.
PLZ HELP!
11-02-2009, 11:01 PM
Post: #39
hello , didn't sat more about that , because I did'n t go further with that mods , due to the lack of infos .
But I can tell you that I bought the caliper .
It's rear VW Golf IV or Audi A3 caliper that are used .
The discs are from rear Nissan Primera 2.0E type P11.
The rear Toyota caliper mount is used , but I tried it and it's not working .
Jamiemirror did that mod , but when I contacted him , I got no answer.
So that's where I'm .
It's true , that's front brake do the most of braking job , but rear are very bad parts . Small pads , badly guidance (rubber) make a spongy pedal .
You can check that : remove rear wheel and twist rear caliper : You' ll see great moves from that part .
And another good reason to improve the rear brakes : handbrake !!!!
very bad stock system (of course doing the job well if used to park the car)
I ' got an hydraulic one fixed (AP Racing) . I had to lenghten the lever , aeroquip hoses , and I use Ferodo DS2500 pads . And It's still far from easy to have it working good .
I asked help here about Golf IV/ Primera mods , but none seems to have the mods done .
Hope it helps a little
Regards
Filh
Filh
Save the RWD cars
11-03-2009, 07:42 AM
Post: #40
ty for the infos
filh Wrote:Jamiemirror did that mod , but when I contacted him , I got no answer.
yes i also tried pm him. there was a brake guide on hachiroku.com.au which were talking about this mod but when i tried to ask the articles author about it he didnt reply.
what the hell is going on? ....
  Bigger brake master cylinder options Koen 10 4,030 01-08-2026 03:12 PM
Last Post: r.ave
Thumbs Up ITB filter options mister86 1 5,610 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 39,255 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 16,674 01-24-2018 02:25 PM
  Rear axle options Dino86 13 20,914 01-08-2018 10:19 PM
Last Post: ditn
