AE86 Rear Brake options.
02-22-2008, 11:25 AM
http://grandzhan.com/miro/Toyota/
Some pictures of front and rear big-brake conversion. Long delay - and long story, but I returned "home" at last |
02-22-2008, 01:22 PM
Looking good jamie!
Are you planning to produce and sell the brackets and other parts? I still have 2 sets of RX7 calipers in my shed from which atleast 1 is usable.. I have to admit I have no plans to put them on my car atm as I'm happy with my current setup, but who knows what the future brings. What did you use for the rears? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
02-22-2008, 01:57 PM
jamiemirror Wrote:We have one modified AE86 here: |
02-22-2008, 02:14 PM
Oops, sorry missed that bit
02-24-2008, 08:23 PM
since you changed the orginal design for the rear. Dont you think you should change the Master Brake booster and the Master Cyclinder to take the acount of the rear set up?
I tend to think that the Stock set up is pretty good as it is. There is wilwood, Brembo, Greddy, etc. But those are just costly but surely great. But this is really interesting since There are many who had needed a better rear set up for higher HP modification. East Coast Toyota http://ectoyotas.com/forum/index.ph Club4AG http://www.club4ag.com/ |
02-25-2008, 11:28 AM
Most of original rear calipers are non-functional due to age, rust and dirt.
I prefer to use better ones + big brake option at the cost of rebuild + little more money spent. Also keep in mind that this car use 276mm fronts + 4-pot calipers so 257mm rears are match. If you like - you can add sub-$50 Willwood brake bias regulator also. Stock brake master works, the feeling is different. AE82 1.6 (even SOHC) use a little bigger diameter for brake master and is bolt-on for AE86 (at least LHD). You can calculate new brake fluid volume required for 4-pots, I tried in the past and result was <5% increase. |
02-25-2008, 01:51 PM
In the TRD Bible found the corresponding AP Racing part nr's for the Group A setup. The scary is, the rear disc is 264 dia versus 260 in the front. Any idea why?
Here's the setup in full according to the bible: Double master cylinder (AP Racing CP2270-16) 15.88mm piston dia (0,625″ 5/8 inch) or 17.88mm (0,7″ piston dia with 35mm stroke,cockpit adjustable balancing bar. 4 piston AP Racing CP2270-86/87S4QR caliper, 4x41,3mm piston dia with, 259,6×25,4mm cooled disc, 2 piston rear AP Racing CP2382 caliper, 264,2×20.7mm solid(? probably not) disc, hydraulic handbrake. The AP parts are cost a fortune, of course.
http://www.ae86.hu |
02-26-2008, 11:58 AM
IMHO there is some mismatching.
03-21-2008, 01:33 AM
intersting threaD
make more money than you thought possible http://p4pp7hfj79xgsa2bqtk.usercash.com |
07-28-2008, 03:09 PM
part number on the primera disks? or even measurements so i can try and match them to a RDA part
| Bigger brake master cylinder options | Koen | 10 | 3,854 |
01-08-2026 03:12 PM Last Post: r.ave |
| ITB filter options | mister86 | 1 | 5,579 |
12-06-2020 10:44 AM Last Post: Bean |
| AE86 starter options | max_ae86 | 12 | 39,112 |
07-28-2019 08:17 PM Last Post: harkes |
| AE86 rear suspension options 2018 | Alex | 9 | 16,592 |
01-24-2018 02:25 PM Last Post: mad.matt |
| Rear axle options | Dino86 | 13 | 20,770 |
