AE86 N2 (big update)
08-03-2008, 08:37 AM
Post: #51
Very good project!!!
Which lights/lambs (blue) do use to the cluster? **COROLLA EE80 - 4AGE 124HP**
08-03-2008, 08:52 AM
Post: #52
It's just some simple leds you can easily find on ebay.
You just have to take off the OEM bulbs and simply replace them with the leds. These ones are supposedly "bright white". 86'LEVIN Track Project |
08-04-2008, 09:59 AM
Post: #53
how hard/easy is it to replace the OEM bulbs in that case? (and does the dimmer still work?)
I think I've seen those LED replacement bulbs on ebay too. Makes the cluster look pretty good anyways |
08-04-2008, 02:15 PM
Post: #54
You can do the job in about 15minutes. It's easy and simple.
The dimmer won't work after the replacement, because you're using leds. If you rotate the dimmer it will only change from lit to completely off. 86'LEVIN Track Project |
01-14-2009, 06:19 AM
Post: #55
A little update:
A "diy" shortshift The aluminum plate was fabricated (similar to the one provided by T3) with a 20mm thickness ![]() ![]() ![]() Cleaning up ![]() The car awaits the upgraded organ... ![]() Cutting... ![]() A 20mm metal cylinder was welded in between ![]() Greasing up... ![]() Paper gaskets Final assembly ![]() ![]() Done! ![]() A good and inexpensive upgrade. It doesn't make a big difference in performance but the gear changes are quicker and smother. The next step is to get a taller gear shifter to have it closer to the steering wheel. And more recently, I finally got some time in Portugal to mount the trailing arms and panhard rod. ![]() ![]() ![]() Panhard rod ends ![]() OEM vs upgraded ![]() A kind of a hassle to take some of them out of the mountings! ![]() Panhard and traction bracket installed ![]() A bit of "tender" hammering was required in order to put those new rod ends into place ![]() And the four link finally installed and ready for its first play: ![]() After a quick spin, I should say that there is a big difference in handling and in the overall driving feel. The car feels so much more direct and the reactions of the rear axle are immediately converted in steering feedback. A really good investment. I didn't have the time to adjust the lenghts of the trailing arms or at least the panhard in order to recenter the rear axle but at least the non-existence of bushing compliance in the rod ends really makes a big difference. Regards from icy Oxford
01-17-2009, 01:09 AM
Post: #56
Very nice! :wink:
Sideways? Just for fun... not a way of life. |
01-17-2009, 02:07 AM
Post: #57
86Pilot Wrote:A little update: You have to test drive my car, 25mm will deff change your mind Awesome project has always Luis
01-18-2009, 09:57 AM
Post: #58
Nice stuff, mate! What make is that four link kit + panhard? It looks very nice
01-19-2009, 02:13 AM
Post: #59
Jan, its a TCS kit. Bought it on ebay from the states.
A lot cheaper than Cusco or similar brands and its with pillowball joints like I wanted. :wink: 86'LEVIN Track Project |
01-19-2009, 02:20 AM
Post: #60
hey Luis your levin is getting better all the time
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 6,209 |
| American Rally 86 UPDATE | dazed_driver | 136 | 197,718 |
03-28-2012 12:53 AM Last Post: dazed_driver |
| 86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 312,923 |
| Supercharged Hachiroku "update" | roadrunner | 20 | 31,384 |
06-02-2011 03:27 AM Last Post: kennedy8383 |
| AE86 two door 1987. in restoration, in Iceland UPDATE | olithor | 12 | 25,957 |
08-08-2009 12:36 PM Last Post: rs1800 |
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img257.imageshack.us/img257/9219/dsc05625dk4.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img300.imageshack.us/img300/8707/dsc05634lw2.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img337.imageshack.us/img337/2915/dsc05637ub6.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img525.imageshack.us/img525/7770/dsc05642kj1.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img257.imageshack.us/img257/7492/dsc05640ml9.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img83.imageshack.us/img83/9668/dsc05651rh6.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img165.imageshack.us/img165/8070/dsc05656ns9.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img179.imageshack.us/img179/2360/dsc05658eo6.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img524.imageshack.us/img524/2026/dsc05662un5.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img301.imageshack.us/img301/1830/dsc05663av7.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img395.imageshack.us/img395/3706/dsc05664xn5.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img293.imageshack.us/img293/3494/dsc00238jc0.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img392.imageshack.us/img392/5807/dsc00864ab1.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img361.imageshack.us/img361/1426/dsc00844mo3.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img387.imageshack.us/img387/714/dsc00862ly8.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img123.imageshack.us/img123/2965/dsc00865ho9.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img361.imageshack.us/img361/8135/dsc00867hb2.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img377.imageshack.us/img377/8305/dsc00885iq9.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img367.imageshack.us/img367/8348/dsc00881dh1.jpg)
![AEU86 AE86 - AE86 N2 (big update) [Image: AEU86 AE86 - AE86 N2 (big update)]](http://img845.imageshack.us/img845/1082/capturar01.jpg)
