AE86 Injector sizes
08-08-2011, 10:29 PM
AE86 Injector sizes
my 4age was a highcomp. map version
@ bean bandit: now i'm going to use supra 7mge (n/a) injectors 312cc high imp. they are straight fit in the ae86 fuell rail and head
'87 levin coupé
[Image: AEU86 AE86 - AE86 Injector sizes]
08-09-2011, 09:08 AM
AE86 Injector sizes
Bean Bandit Wrote:
Uzelac Wrote:Now i use 295cc injectors from Porsche 944 2.5 N/A. I believe that's good size for modified NA 4AGE with ITB's.
interesting, are the Porsche inectors a straight fit or did you need some fab work and are the high or low imp?
sorry for the highjack
They are low impedance and not a straight fit.
Although, it was very easy to modify them on lathe. Stock head, stock fuel rail and FRP. And they are grey Smile
08-09-2011, 07:50 PM
AE86 Injector sizes
taken from another forum;
early bigport 4age's are 220cc @ 48psi (blue top), low ohm
later bigport 4age's are like 240cc @ 48psi (tan), low ohm
smallport 4age's are 250cc @ 48psi, high ohm
silvertop and blacktop use the same (side feed) are 270cc @ 48psi, high ohm
4agze is reddish and 365cc @ 48psi
The bigport injectors are bigger than I thought! :S
08-12-2011, 12:10 PM
AE86 Injector sizes
Bigger ? Smile
High reving 1.6 engine like 4AGE should use way above 200cc.
08-12-2011, 05:15 PM
AE86 Injector sizes
Stock starlet gt/glanza (4efte) injectors are 295cc high imp. (Just for reference). No mods needed to fit.
Japan 4 Ever
08-12-2011, 07:59 PM
AE86 Injector sizes
The bleu injectors from your swiss MAF Hachi are 210cc low-imp injectors.
On the bleutop you also ave the grey like the one that patrik show us and it's are 182cc low-imp
On the redtop Map you can have pink one that are 200cc low-imp
On the redtop hi-comp (small port) it's are green and are 250cc hi-imp
Wave
SR Team
BURN THE RUBER NOT YOUR SOUL!
08-12-2011, 11:06 PM
AE86 Injector sizes
Huh.. could be.
I allways found info of ~185cc so i concluded mine blue are that size.
Could be that they are bigger.
btw. what is default fuel pressure. around 2.7 bar, 36psi ?
08-13-2011, 01:10 AM
AE86 Injector sizes
Everything is already here !
http://www.aeu86.org/viewtopic.php?t=500
Wink
08-13-2011, 02:40 PM
AE86 Injector sizes
Thanks for the help, Just need to find a set now Big Grin
  Injector voltage problem [fixed] d3nso 16 23,630 04-03-2016 12:39 PM
Last Post: d3nso
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 7,419 02-20-2016 11:48 AM
  Injector sizes info ZaX 19 42,799 07-17-2013 01:54 AM
Last Post: jondee86
  pink injector resistance Apsogos 2 5,266 10-01-2012 09:00 AM
  Question regarding wheel sizes? heshan 3 5,867 05-21-2012 09:22 PM
Last Post: Saber
