AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
12-17-2013, 06:49 PM
Post: #411
jdm86gtz Wrote:
Jan Pedersen Wrote:Where do I get an air box like that for my 4AGE? It looks awesome!
http://page8.auctions.yahoo.co.jp/jp/auction/h180594989
I am looking for one with a much bigger volume to get an improvement over this:
[Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]
06-09-2014, 11:56 PM (This post was last modified: 06-10-2014 12:02 AM by Conrad.)
Post: #412
Update Time..... A few more bits and pieces but more importantly its ALIVE, it runs Big Grin
Cutting out for the tailgate locks
and fitted...
Rear Quarter Window fitting
Radiator modified to sit lower, pins welded on and brackets positioned
Air / Water Separator Fabricated and fitted
...and here it is running on its very first start up.... (no exhaust system connected to the manifold)
Click the picture Smile
I'm currently taking HRT ~ Hachi Roku Therapy Big Grin
06-10-2014, 10:45 AM
Post: #413
Hurray! sounds nice, must feel good after so long
06-10-2014, 11:33 AM
Post: #414
Hurray!:thumbs:Respect!
Sounds great!
06-11-2014, 09:51 PM
Post: #415
That was a really good idea for the locks on the hatch. I might just steal that (idea Wink) from you.
11-26-2014, 04:06 PM
Post: #416
Ok here's the updates from a while ago....
Air box back plate and trumpets mounted.
Air box fitted, lid retainer clips fitted also.
Window slider, door handles, lock and window trims fitted.
Rear window trims fitted, tailgate aero catches fitted.
Hydraulic handbrake, cable handbrake setup
The pedal box needed relocating for the master cylinder clearance against the bulkhead, this was achieved by water jet cutting a plate that mounted onto the original Tilton pedal set mounts on the chassis and then allowed the Tilton pedal set to be mounted on the plate 1" further forward.
And mounted....
That's all for now folks, next up is to finish a few little odds and ends, map it on the dyno and then I will bring it home to finish off the other little stuff like sorting the hole on bulkhead, remount the chassis plate, air box intake hose and scoop, fit side skirts, fit rear bumper, fit front bumper, fit splitter and decide on final paint scheme etc
12-16-2014, 04:27 PM
Post: #417
Well it's mapped, 195 ATW on Dyno Dynamics, holds power to 9000 rpm then it starts to taper away towards 9400rpm.
It's a lot less than I had hoped for, it would seem something's not working well together but for now let's just get it home, MOT'd, finish a few small bits and on get it on the road, it's only been 7 years :lol:
12-16-2014, 10:49 PM
Post: #418
Stock cams ?
230+ engine hp?
Sounds great if you ask me.
12-17-2014, 12:10 PM
Post: #419
No mate, it has Toda Cams.
12-21-2014, 01:09 AM
Post: #420
will need to look at your dyno chart
  ae86 racecar with beams engine bakonick 148 207,472 04-23-2024 10:06 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 118,783 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 897,374 09-03-2017 09:24 PM
  Beams Levin build mannix20vt 5 11,974 01-27-2016 12:39 AM
Last Post: mannix20vt
  Another AE86, Duracell. Now with VEMS, and cage... Uzelac 62 106,706 06-22-2015 02:56 PM
Last Post: Uzelac
