AE86 5th gear too big RPM can be customized ?
06-26-2009, 09:54 PM
Hi guys i need some explanation i see that there is only maybe 200rpm difference between 4th and 5th gear on typical AE86 GT T50 transmission can that be customized to maintain lower RPM because when driving on highway it is just too much. In my case i drive not so speedy only around 100-110km/h enjoying the ride but in 120km/h for example you just have 4000rpm in my case.
85' AE86 GT coupe lifetime project since 2005
06-26-2009, 11:56 PM
You can change the input shaft ratio. The 5th gear is an overdrive gear and will be taller when you make the gearbox close ratio:
http://www.billzilla.org/drivetrn.htm
[Image: AEU86 AE86 - AE86 5th gear too big RPM c...stomized ?]
06-27-2009, 10:19 PM
i knoƧw that the compagny REVOLVER in Japan make a long ratio for the 5th gear.
But i can't get a link sorry.
SR Team
BURN THE RUBER NOT YOUR SOUL!
06-27-2009, 11:23 PM
Why not fit a 4.1 crown wheel and pinion to your rear end , as your car will have a 4.3 from factory. I fitted a 4.1 to one of my road cars and it was very good to drive on the open road and around the city.
06-27-2009, 11:52 PM
Changing the fial drive will be the easiest and cheapest way to go.
You can also change the ratio of your gears.
Revolver offers various ratios:
http://www.revolver-jp.co.jp/products/drivegear.html
If you need anything from there hit me up.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
  4AGE Big port head failure Blaze0010 3 649 01-23-2026 03:35 PM
Last Post: totta Crolla
Wink Can Wing Mirror Glass be Replaced? chrisae86 4 3,083 10-05-2025 11:09 PM
Last Post: chrisae86
  No idle below 2000 rpm rich running Steller Engineering 3 3,208 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 12,414 07-28-2022 10:48 PM
  Can you convert your 86 back too the original state? gh0st 7 5,577 04-25-2022 04:25 PM
Last Post: gh0st
