AE70 Sprinter Engine qustion
04-23-2007, 11:51 AM
Hey guys,
Well this is my fist post of this site i have been looking for some sites for my new AE70 Sprinter but no one seems to have anything on them!!!
My question is really quite simple to anyone who knows this car and the 4age
Question as follows;
I need to know if a blue top 4age will fit into the engine bay using the original engine mounts
All so how much power dose a standard 3-AU engine have
Thanks so much for looking at my post
David.
04-23-2007, 05:09 PM
Hi, cool car..lovin the 70's box design.
Just guessing since I dont have any experience with te/ke70's: you probably need the ae86 crossmember to fit the 4age in it, since the engine mounts connect to that. Might not be necessary if you already have an 'A' family engine though.
04-24-2007, 03:27 PM
And Ill just add that the 3AU gives somewhat between 60 to 65 hp Smile
86ers.org
AE86 x GXE10
04-24-2007, 03:51 PM
if it's an AE70, with any a-series engine in, you just can put any other A series engine in, so yes: a 4A-GE is bolt on Smile
if i'm correct, the 3A-U AE70 uses the K40/K50 gearbox with an A series bellhousing, so it will fit, but i'm not sure if the gearbox made for little k-engines can cope with the 4A-GE, but converting to hydraulic clutch and T50 gearbox isn't that hard.
04-24-2007, 07:14 PM
Doc, even if it's K-gearbox if clutch housing was intended for use with A-series engine, it can be used with any A-engine too.
04-24-2007, 11:16 PM
yeah, i know, but like i said, i don't know if the K40/50 can take the power from a 4A-GE Smile
04-25-2007, 05:03 AM
Thats for the info guys! i am looking into a nice hotted up blue top for it now and a w serries box for it Smile
thanks david
04-25-2007, 10:16 PM
4age to W box bellhousing will cost a lot..
  Good pics of rear decals for GT-Apex Sprinter Trueno needed Lauren 20 39,933 10-16-2014 06:53 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 11,248 10-30-2013 11:18 PM
  Wiring diagram for AE70 & TE71 DRFT 1 8,236 01-09-2010 03:32 PM
Last Post: DRFT
  Under shim bucket kit qustion Jimmi The Kid 13 22,072 07-08-2009 04:04 PM
  Need engine,any engine Apolan 25 29,114 10-29-2006 06:55 PM
