'85 2door from Belgium
10-24-2007, 05:09 PM
Post: #41
Oh and another thing, is there a way to check the duration of the camshaft without taking the cam covers of? I think there are different cams in there as the idle is a bit of. The timing i run now is off the scale, and when i try to get between 10 and 20 it idles better, but when i push the gas it sounds like it gonna stall.
My rolla is actually suprisingly fast, I stood at the red lights next to my dad in the mr2 turbo and i was faster then him and he was pushing hard. The mr has 240bhp and standard values from 0-100kmh are 6.5 so either the rolla is really fast or there is something really wrong with my dads car I was hoping for the first option of course
No Smorking AE86 |
10-24-2007, 06:14 PM
Post: #42
save up for trd bushings if you need to keep the original look. They are made of harder rubber, and probably better than polyurethane ones anyway.
10-24-2007, 08:50 PM
Post: #43
tnx for the tip
and is it possible to replace them myself, or are they placed using a machine? i know newer cars need a special machine to get them pressed in? No Smorking AE86 |
10-24-2007, 09:41 PM
Post: #44
It's all possible by hand..with the help of a benchscrew (vice grip or whatever it's called). Getting the old ones out is usually harder.
10-25-2007, 08:06 PM
Post: #45
ok tnx i'll be having fun attacking the suspension soon, right now the car is prepped for tomorrow, homemade drift e-brake, i's now completely empty
, al the stuff (tires, tools,...) everything is put in the towing car i'll get some pictures upwhen i get, if it still drives after :wink:
No Smorking AE86 |
10-26-2007, 06:38 PM
Post: #46
Today was fun, too bad i had to stop halfway
Gonna check monday what a standard replacement would cost me at toyota, and any idea on aftermarket parts would be handy aswell. i checked fensport and a sportier clutch kits comes to 450€ which seems a little high to me, probably i'll a standard toyota one and i'll be back on 8dec in zolder to try again, it was actually going pretty good. Not had a lot of time to take pictures tho. No Smorking AE86 |
10-26-2007, 09:28 PM
Post: #47
I had to change mine when I bought the car.
I got a Sachs oem replacement clutch. Cost me 150euro (with 20%discount) for the whole set. (cover/clutch/bearing)!! Sachs can handle a bit more power. Mine is still fine after one driftday and the occasional sunday clutch-kicks. I'll post the part-numbers tomorrow.
10-26-2007, 09:44 PM
Post: #48
If you dont want to keep changing clutches after every one or two drift days, get in touch with max misawa (http://www.illegalgarage.com) and buy one of his clutches. They're very popular in the us because they can handle a lot of drifting, and are still very streetable.
10-27-2007, 04:58 PM
Post: #49
tnx for the tips guys
went to toyota and a standard replacement one would cost me 325€ including work. I can't do it myself right now as my arm is in a cast, but they told me i could buy a diiferent clutch myself and they would place it for me No Smorking AE86 |
10-29-2007, 04:02 PM
Post: #50
The clutch is bought and will be put in by toyota next wednesday, and i signed up for driftschool december 8 to have another go
No Smorking AE86 |
| A Portuguese Hachiroku in Belgium (lots of pictures) | Lt86 | 25 | 30,929 |
04-05-2017 08:08 AM Last Post: Lt86 |
| levin from Belgium - demee76 | demee76 | 46 | 75,850 |
08-28-2015 03:06 PM Last Post: demee76 |
| Belgium project | Roger | 12 | 21,256 |
08-03-2015 08:46 PM Last Post: Roger |
| belgium ae86 | boedtsie | 8 | 15,141 |
06-01-2015 05:25 PM Last Post: Lt86 |
| ae 86 from Belgium [Brembo installed] | seb | 67 | 107,526 |
05-19-2013 07:52 AM Last Post: seb |
