'85 2door from Belgium
07-26-2012, 11:08 AM
Post: #471
<=red ae86 yesterday Smile
07-26-2012, 07:07 PM
Post: #472
Ah ok, have seen you around a few times before on trackdays.
No Smorking AE86
07-27-2012, 11:09 AM
Post: #473
yes i have done the skylimit trackdays a couple times now Smile
If only i would live a bit closer i could come more.
07-27-2012, 03:23 PM
Post: #474
next time driftschool aswell? Tongue It's nice to see more and more oldschool cars turning up at events.
No Smorking AE86
07-29-2012, 03:07 PM
Post: #475
I would love to but there are alot of things i need to do first.
installing a w58/4AGZE probably and the slowly sideways rally restoration.
Drifting is something i want to learn Smile
08-27-2012, 11:46 PM
Post: #476
Anyone notice something wrong in the next pic?
[Image: AEU86 AE86 - '85 2door from Belgium]
No Smorking AE86
08-28-2012, 12:22 AM
Post: #477
do you put a s14 rear end?
SR Team
BURN THE RUBER NOT YOUR SOUL!
08-28-2012, 07:06 AM
Post: #478
Nope, e36 rear end. Subframe is much smaller and a lot easier to get in the right place.
No Smorking AE86
09-01-2012, 10:24 PM
Post: #479
Ok so a little update is on order.
Since the stock corolla rear axle couldn't handle the mega power of the stock 4age, it will crap it's pants with beemer powers. So having a complete m3 meant I could switch over the rear subframe from the bmw.
Dimensions of the subframe are much smaller then s13/14 items, and better suited for the little corolla.
So the bmw subframe and the space it will go in.
Had to modify the camber arms, they took up a lot of room meaning I had to cut away too much. I won't be running bmw rear suspension.
Then made a frame to weld to the bottom of the car, this is still undergoing strenghtening so no worries Wink
As you can see here, the ae suspension bolts on directly to the bmw subframe, no mods what so ever.
That's when we rolled the car out the garage for the first time, still need to tweak some of the allignement, haven't got any pics of the toe-arms, but adapted them to fit to the corolla's lower control arm. No adjustment left, but we made them to have 0° toe, which always worked perfect on the corolla.
Also the track of the m3 is 10cm wider as the corolla. Got some overfender to fit back, so not really worried about fitment.
Only thing I'm worried about is lack of grip on the rear, so have some 10j wheels with 255 tires to try out Wink
Next update:
Custom driveshaft
Wiring
Winning!!!
No Smorking AE86
09-01-2012, 10:38 PM
Post: #480
Looks good. Can't wait to see it in action. Thumbs up!
ハチロク
Photo A Portuguese Hachiroku in Belgium (lots of pictures) Lt86 25 30,506 04-05-2017 08:08 AM
Last Post: Lt86
  levin from Belgium - demee76 demee76 46 75,171 08-28-2015 03:06 PM
Last Post: demee76
  Belgium project Roger 12 21,025 08-03-2015 08:46 PM
Last Post: Roger
  belgium ae86 boedtsie 8 15,013 06-01-2015 05:25 PM
Last Post: Lt86
  ae 86 from Belgium [Brembo installed] seb 67 106,139 05-19-2013 07:52 AM
Last Post: seb
