'85 2door from Belgium
01-31-2009, 07:19 PM
Post: #201
Smile
ハチロク
[Image: AEU86 AE86 - '85 2door from Belgium]
01-31-2009, 07:36 PM
Post: #202
yup
No Smorking AE86
04-27-2009, 04:49 PM
Post: #203
A little update,
The new driftseason is coming and I changed some stuff on the corolla.
- D2 coilovers installed
- Driftworks casterarms installed
- Painted interior
- Modified rear bumper mounting
- Fixed wiring under dash
Still to do
- Fit traction brackets
- Weld seat frame
- Drive it Cool
I bought myself a Mazda 626 break so I can tow the corolla to competitions, and deregistered the corolla.
A few pictures:
I painted it just with spray cans, came out better then expected.
This is very close, but the wheels only rubs the bumper very slightly, if I go 195/45-15 on the front it'll clear everything
My corolla next to the Mazda Tongue
That's it for now, 6/7 June is the first competition for me. I am running the Pro Class of the Yokohama cup this year.
See you in Brustem :wink:
No Smorking AE86
04-27-2009, 10:48 PM
Post: #204
It is looking weird with the casterarms installed... Blush
But hey, its free camber when turning so who cares about that! Thumbs up!
Nice stretched tires on the rear btw! Smile
04-27-2009, 10:49 PM
Post: #205
yeah it looks weird, the wheels sit further to the front of the car.
Rears are 8x15 with 185/55
04-27-2009, 11:20 PM
Post: #206
you just fucked up your wheel base Smile Good luck with that one !
Car is nice. But I hope you will spend some time on the arches making them nice
04-27-2009, 11:33 PM
Post: #207
they are adjustable caster arsm tho, i can adjust then to stock setting :wink: I set it like this for clearance, i'll see how the driving changed soon.
arches are getting done, but want to practise some more before i do that.
No Smorking AE86
05-09-2009, 07:03 PM
Post: #208
Took robokill's advice and got to work on the arches :wink:
Been working on them for 3 days and now the rear ones are finished. Everything has been de-rustified Tongue and rear ones are now in primer.
Right side
Left side
I'm pretty happy with the result, not perfect but better then it was.
Fronts need a little work but not as much as the rears. I also filled the keyhole in the trunk and the holes for the screws for the license plate.
Also fixed some of the dents, scratches and starting rust spots.
I tried something with the rear lights, came out good and I like it a lot.
I made the orange part red, just used some red laqcuer(spelling?)
And specially for banpei Tongue
The interieur is finished aswell, forgot to take some pictures. The drivers side seat frames is welded in and everything has been sprayed black.
I signed up for ODC round 2/Yokohama cup Round 1 on the 6&7th of June in Brustem. More info found here http://www.skylimitdrift.be.
Wave
No Smorking AE86
05-09-2009, 07:26 PM
Post: #209
nice front negative camber how you do it ?
like your wheels Tongue same as mine
that huge steering angle was made by the new caster arms?
AE86 owner
05-09-2009, 08:00 PM
Post: #210
|BUDA| Wrote:nice front negative camber how you do it ?
The coilovers have adjustable camber plates, but with these we could adjust more then with my old ones.
You have good taste in wheels Tongue we use 25mm spacers with mine.
For the steering angle we used battleversion no2 spacer kit, 2 spacer that go on your steering arms. More info on the kit I use here http://www.tlsperformance.com/bavestkit2ae.html
Photo A Portuguese Hachiroku in Belgium (lots of pictures) Lt86 25 30,518 04-05-2017 08:08 AM
Last Post: Lt86
  levin from Belgium - demee76 demee76 46 75,187 08-28-2015 03:06 PM
Last Post: demee76
  Belgium project Roger 12 21,031 08-03-2015 08:46 PM
Last Post: Roger
  belgium ae86 boedtsie 8 15,014 06-01-2015 05:25 PM
Last Post: Lt86
  ae 86 from Belgium [Brembo installed] seb 67 106,165 05-19-2013 07:52 AM
Last Post: seb
